35" m/t's on 06 1500 4x4 with leveling kit.. problems??
Ok heres the deal.. I have a 06 1500 Sport QC SB 4x4... I am planning to put 35" tires on my truck I understand they will rub on the stock height but if I have a 2.5" front leveling kit and a 2" rear block lift should I be ok? im either going with Pro Comp Xtreme M/T or Mickey Thompason Baja MTZ Radials mabey even Dick Cepek Mud Country.. My next question is I am keeping my stock 20" rims.. will it fit on the tires (12"+ I think wide).. and/or will it fit on the truck without wheel spacers? any input at all will help me a lot thanks.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
'06 Ram 1500 Quad Cab HEMI 4x4 - LEER 800 Power FB Tonneau Cover, Flowmaster Dual Cat Back Side Exits - Super 40 swap, 20% Front tint, 8000K HID's
'91 Mustang LX Coupe - 306 cu. in., h/c/i, chiped, 3.73 tons of work good for 387.9 rwhp n/a
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Nope. Im in the same boat as you. They rub in the front against the control arm. So I just purchased wheel spacers that didnt fit. So im thinking about buying new rims.
__________________
2006 Dodge Ram 1500 Hemi 4x4, 15% Tint, Smoked LED Taillights, Projector Halo HID Headlights, 2.5" Level, 2 12" Kenwood Subwoofers, 1800 Watt Amp, White Truck Club Member #1, 33" Toyo Open Country M/T's, 20" Black Rockstars
Unlike the '02-'05 torsion bar front trucks, which will just make it with 12.5" wide tires on the stock wheels, the '06+ coil overs seem to have just a tad less room in there. You'll need spacers or even better a wheel with a proper backspacing and offset.
As far as the tires, 35's will fit in the wheel well with just a level and will be fine if you are pretty much doing this for the look, but if you intend to wheel at all, you'll wish you had a LOT more room for articulation.
If you intend to do any off-roading, you'll be much better off either going with at least a 4" suspension lift or a 3" body lift/level kit combination.
If you are limited to only doing a level, then stick to 33" tires. You'll not only perform better but get better gas mileage and put less wear on front end components...
__________________
4.56 Gear Club Founding Member
Yes, that is a gun in my pocket and No, I am not happy to see you!
