Another idea I found today was mixing race gas with regular fuel. It'd be a little more expensive than octane booster but it should work much better. Any idea on what ratio to mix at?
personally, i wouldnt risk my engine by using boosters, and ****ty gas. its not exact, and theres no telling what could happen. the manual says to use 89 or higher, so thats what i use. you should be especially concerned with the octane you are using if you get a programmer. the advanced timing requires the higher octane, and you run a higher risk of messing something up if you dont run the right gas.
I saw a video on youtube that said if you add just 2 oz. of Acetone to your tank, then it does the same thing as using high octane gas. "Acetone makes your fuel vaporize better", is what the vid said. Can anybody bust/confirm this?
I have ran C16 in my truck before and it ran like a badass!!!! lol but i dont have CATs in my truck ... Smelled really good to lol
