Last edit by: IB Advertising
Browse all: Engine Guides
- Dodge Ram 2009-Present: How to Change Oil
Step by step instructions for the do-it-yourself repairs.
Oil, change, types
#101
The only thing I can think of that would get "hurt" by changing the oil early is your wallet.
#103
Well I did my oil change today. The truck had 3619 miles on it. I used Mobile 1 full synthetic, and a Dodge 899 filter. When I bought the truck the salesman told us NOT to change the oil early, and to wait till the message center told us to. Well after most of the 3619 miles are towing (probably about 2200 of them) I figured it was time, and I wanted to get the Mobile 1 in it. When I went to reset the oil life meter, I saw the last reset was 3610 miles ago. And the oil life message said there was still 56% of the oil life left. So now I'm wondering if the oil was changed at 9 miles, or if the reset meter was just reset. If they did change the oil, what happened to waiting till the message center said to. I don't see how changing the oil a little early could do damage. It's hard to understand what to do, when the salesman says to do one thing, and the manual says to do something else. I'm guessing the manual is the right thing to follow. Any thoughts. Thanks.
Follow the manual... it wont let you down like a salesman will.
#105
#106
ADDED:
If your dealer did it, i`m sure they know that it has to have 5w20.
If you question it, call your dealer that did it.
#107
I've posted this in another thread, but it might be worth repeating here.
Apparently for 2014 5.7 Hemis the oil change interval is determined by the oil life counter and based on the EVIC message which informs the driver when it is due. The manual clearly states, however, that you should never exceed 10,000 miles.
It appears my dealer didn't know this either. They changed the oil at 5129 miles while the Oil Change gauge was showing that I had 51% oil life remaining.
Dusty
2014 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 005200 miles.
Dusty
#108
Dusty
Dusty
#109
