Check Engine Codes
Check Engine Codes
Courtesy of Sarguy01
These are all of the check engine codes from the service manual. If you have a code reader or get them read for free at an auto parts store, you can figure what the problem is. I am not saying everyone should fix the issues they may have by themselves, I am just posting for everyone's information. I know I miss having the ability to check codes by turning the key on and off three times.
Sorry if some are duplicates. It took a while to copy these.
B1000-92-A/C SWITCH REQUEST INPUT - PERFORMANCE OR INCORRECT OPERATION
B1000-A/C SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B1009-92-RECIRCULATION SWITCH REQUEST INPUT - PERFORMANCE OR INCORRECT OPERATION
B1009-RECIRCULATION SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B1015-12-REAR DEFROST SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B1015-REAR DEFROST SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B1030-11-EVAPORATOR TEMPERATURE SENSOR - CIRCUIT SHORT TO GROUND
B1030-12-EVAPORATOR TEMPERATURE SENSOR - CIRCUIT SHORT TO BATTERY
B1031-EVAPORATOR TEMPERATURE SENSOR CIRCUIT LOW
B1032-EVAPORATOR TEMPERATURE SENSOR CIRCUIT HIGH
B1034-INFRARED TEMPERATURE SENSOR CIRCUIT LOW
B1035-INFRARED TEMPERATURE SENSOR CIRCUIT HIGH
B1040-PANEL MODE DOOR 1 CONTROL CIRCUIT/PERFORMANCE
B1043-PANEL MODE DOOR 1 CONTROL CIRCUIT OPEN
B1044-PANEL MODE DOOR 1 TRAVEL RANGE TOO SMALL
B1045-PANEL MODE DOOR 1 TRAVEL RANGE TOO LARGE
B1058-13-RECIRCULATION DOOR CONTROL - CIRCUIT OPEN
B1058-92-RECIRCULATION DOOR CONTROL - PERFORMANCE OR INCORRECT OPERATION
B1058-RECIRCULATION DOOR CONTROL CIRCUIT/PERFORMANCE
B105B-RECIRCULATION DOOR CONTROL CIRCUIT OPEN
B105C-00-RECIRCULATION DOOR TRAVEL RANGE TOO SMALL
B105C-RECIRCULATION DOOR TRAVEL RANGE TOO SMALL
B105D-00-RECIRCULATION DOOR TRAVEL RANGE TOO LARGE
B105D-RECIRCULATION DOOR TRAVEL RANGE TOO LARGE
B107C-A/C REFRIGERANT PRESSURE SENSOR CIRCUIT HIGH
B109B-PANEL MODE DOOR 2 CONTROL CIRCUIT/PERFORMANCE
B109E-PANEL MODE DOOR 2 CONTROL CIRCUIT OPEN
B109F-PANEL MODE DOOR 2 TRAVEL RANGE TOO SMALL
B10A0-PANEL MODE DOOR 2 TRAVEL RANGE TOO LARGE
B10A5-LEFT BLEND DOOR 1 CONTROL CIRCUIT OPEN
B10A6-LEFT BLEND DOOR 1 TRAVEL TOO SMALL
B10A7-LEFT BLEND DOOR 1 TRAVEL TOO LARGE
B10A8-LEFT BLEND DOOR ACTUATOR PERFORMANCE
B10AC-RIGHT BLEND DOOR CONTROL CIRCUIT OPEN
B10AD-RIGHT BLEND DOOR TRAVEL TOO SMALL
B10AE-RIGHT BLEND DOOR TRAVEL TOO LARGE
B10AF-RIGHT BLEND DOOR ACTUATOR PERFORMANCE
B10B2-00-A/C COOL DOWN TEST PERFORMANCE
B10B2-A/C COOL DOWN TEST PERFORMANCE
B10BB-LEFT HEATED SEAT SWITCH INPUT CIRCUIT STUCK
B10BC-RIGHT HEATED SEAT SWITCH INPUT CIRCUIT STUCK
B10C4-11-HEATED STEERING WHEEL CONTROL - CIRCUIT SHORT TO GROUND
B10C4-12-HEATED STEERING WHEEL CONTROL - CIRCUIT SHORT TO BATTERY
B10C4-13-HEATED STEERING WHEEL CONTROL - CIRCUIT OPEN
B10C4-1E-HEATED STEERING WHEEL CONTROL - CIRCUIT RESISTANCE OUT OF RANGE
B10E9-BLOWER MOTOR CONTROL CIRCUIT LOW
B10EA-BLOWER MOTOR CONTROL CIRCUIT HIGH
B10ED-REAR DEFROST CONTROL CIRCUIT OVERCURRENT
B1141-CLIMATE SYNC SWITCH PERFORMANCE
B114C-LEFT REAR HEATED SEAT SWITCH STUCK
B1151-RIGHT REAR HEATED SEAT SWITCH STUCK
B1184-LEFT TEMP UP SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B1185-LEFT TEMP DOWN SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B1186-RIGHT TEMP UP SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B1187-RIGHT TEMP DOWN SWITCH REQUEST INPUT CIRCUIT/PERFORMANCE
B11C0-13-STEERING WHEEL HEATER POWER SUPPLY - CIRCUIT OPEN
B11C1-13-REAR HEATED SEATS POWER SUPPLY - CIRCUIT OPEN
B11C2-13-FRONT MODE DOOR 1 CONTROL - CIRCUIT OPEN
B11C2-92-FRONT MODE DOOR 1 CONTROL - PERFORMANCE OR INCORRECT OPERATION
B11C3-00-FRONT MODE DOOR 1 TRAVEL RANGE TOO SMALL
B11C4-00-FRONT MODE DOOR 1 TRAVEL RANGE TOO LARGE
B11CB-13-MAIN/LEFT TEMPERATURE DOOR 1 CONTROL - CIRCUIT OPEN
B11CB-92-MAIN/LEFT TEMPERATURE DOOR 1 CONTROL - PERFORMANCE OR INCORRECT OPERATION
B11CC-00-MAIN/LEFT TEMPERATURE DOOR 1 TRAVEL TOO SMALL
B11CD-00-MAIN/LEFT TEMPERATURE DOOR 1 TRAVEL TOO LARGE
B123F-MENU SWITCH STUCK
B127A-COMPASS PERFORMACE
B1285-PARK ASSIST DISABLE SWITCH PERFORMANCE
B1286-COMPASS / TEMP BUTTON PERFORMANCE
B1287-RESET SWITCH PERFORMANCE
B1288-TRIP / TOGGLE SWITCH PERFORMANCE
B1295-11-PTS SENSOR 8 CIRCUIT SHORT TO GROUND
B1295-12-PTS SENSOR 8-CIRCUIT SHORT TO BATTERY
B1295-25-PTS SENSOR 8-SIGNAL SHAPE / WAVEFORM FAILURE
B1295-92-PTS SENSOR 8-PERFORMANCE OR INCORRECT OPERATION
B1296-11-PTS SENSOR 9-CIRCUIT SHORT TO GROUND
B1296-12-PTS SENSOR 9-CIRCUIT SHORT TO BATTERY
B1296-25-PTS SENSOR 9-SIGNAL SHAPE / WAVEFORM FAILURE
B1296-92-PTS SENSOR 9-PERFORMANCE OR INCORRECT OPERATION
B1297-11-PTS SENSOR 10-CIRCUIT SHORT TO GROUND
B1297-12-PTS SENSOR 10-CIRCUIT SHORT TO BATTERY
B1297-25-PTS SENSOR 10-SIGNAL SHAPE / WAVEFORM FAILURE
B1297-92-PTS SENSOR 10-PERFORMANCE OR INCORRECT OPERATION
B1298-11-PTS SENSOR 11-CIRCUIT SHORT TO GROUND
B1298-12-PTS SENSOR 11-CIRCUIT SHORT TO BATTERY
B1298-25-PTS SENSOR 11-SIGNAL SHAPE / WAVEFORM FAILURE
B1298-92-PTS SENSOR 11-PERFORMANCE OR INCORRECT OPERATION
B1401-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1402-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1403-FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1405-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1406-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1407-FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1409-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B140A-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B140B-REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B140D-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B140E-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B140F-REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1420-AUDIO CASSETTE ERROR/INOPERABLE CASSETTE
B1421-AUDIO CD READ ERROR/INOPERABLE DISC
B1422-AUDIO DVD READ ERROR/INOPERABLE DISC
B1423-VES DVD READ ERROR/INOPERABLE DISC
B1424-IMPROPER DVD-WRONG REGION
B1427-REMOTE RADIO SWITCH INPUT CIRCUIT HIGH
B1428-REMOTE RADIO SWITCH INPUT CIRCUIT STUCK
B1429-RADIO DISPLAY HIGH TEMPERATURE
B142A-RADIO UNIT HIGH TEMPERATURE
B142C-VES VIDEO SCREEN DISCONNECTED
B142D-AUDIO ANTENNA NOT CONNECTED
B142E-GPS ANTENNA NOT CONNECTED
B142F-SATELLITE RADIO ANTENNA NOT CONNECTED
B1430-SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
B1438-VOICE RECOGNITION SWITCH STUCK
B1439-PHONE SWITCH STUCK
B143A- MICROPHONE 1 CIRCUIT PERFORMANCE
B143B-MICROPHONE 1 CIRCUIT LOW
B143C-MICROPHONE 1 CIRCUIT HIGH
B143D-MICROPHONE 2 CIRCUIT PERFORMANCE
B143E-MICROPHONE 2 CIRCUIT LOW
B143F-MICROPHONE 2 CIRCUIT HIGH
B1459-TELEMATICS MIRROR CONTROL CIRCUIT LOW
B1460-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1461-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1462-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1463-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1464-CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B1465-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1466-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1467-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1468-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1469-CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B146A-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B146B-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B146C-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B146D-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B146E-CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B146F-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1470-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1471-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1472-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1473-CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B1474-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1475-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1476-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1477-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1478-CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B1479-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B147A-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B147B-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B147C-CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
The following users liked this post:
coalminer ron (11-06-2021)
b147d-channel 6 audio speaker output circuit shorted together
b147e-channel 7 audio speaker output circuit performance
b147f-channel 7 audio speaker output circuit low
b1480-channel 7 audio speaker output circuit high
b1481-channel 7 audio speaker output circuit open
b1482-channel 7 audio speaker output circuit shorted together
b1483-channel 8 audio speaker output circuit/performance
b1484-channel 8 audio speaker output circuit low
b1485-channel 8 audio speaker output circuit high
b1486-channel 8 audio speaker output circuit open
b1487-channel 8 audio speaker output circuit shorted together
b1488-cabin eq mismatch performance
b14b9-channel 9 audio speaker output circuit performance
b14ba-channel 9 audio speaker output circuit low
b14bb-channel 9 audio speaker output circuit high
b14bc-channel 9 audio speaker output circuit open
b14bd-channel 9 audio speaker output circuit shorted together
b14be-channel 10 audio speaker output circuit performance
b14bf-channel 10 audio speaker output circuit low
b14c0-channel 10 audio speaker output circuit high
b14c1-channel 10 audio speaker output circuit open
b14c2-channel 10 audio speaker output circuit shorted together
b14c3-channel 11 audio speaker output circuit performance
b14c4-channel 11 audio speaker output circuit low
b14c5-channel 11 audio speaker output circuit high
b14c6-channel 11 audio speaker output circuit open
b14c7-channel 11 audio speaker output circuit shorted together
b1502-steering wheel control down switch performance
b1503-steering wheel control right switch performance
b1539-satellite video antenna performance (not connected)
b156b-satellite radio antenna circuit
b1601-left solar sensor circuit low
b1602-left solar sensor circuit high
b1604-right solar sensor circuit low
b1605-right solar sensor circuit high
b1607-headlamp switch input circuit low
b1608-headlamp switch input circuit high
b160a-panel dimmer input circuit low
b160b-panel dimmer input circuit high
b160f-11-twilight/ambient light sensor input - circuit short to ground
b160f-12-twilight/ambient light sensor input - circuit short to battery
b1610-ambient light sensor 1 input circuit low
b1611-ambient light sensor 1 input circuit high
b162b-left low beam control circuit low
b162d-left low beam control circuit open
b162f-right low beam control circuit low
b1631-right low beam control circuit open
b1633-left high beam control circuit low
b1635-left high beam control circuit open
b1637-right high beam control circuit low
b1639-right high beam control circuit open
b163b-front left turn control circuit low
b163d-front left turn control circuit open
b163f-front right turn control circuit low
b1641-front right turn control circuit open
b1643-rear left turn control circuit low
b1645-rear left turn control circuit open
b1647-rear right turn control circuit low
b1649-rear right turn control circuit open
b164a-11-driver mirror signal lamp control - circuit short to ground
b164a-15-driver mirror signal lamp control - circuit short to battery or open
b164e-11-passenger mirror signal lamp control - circuit short to ground
b164e-15-passenger mirror signal lamp control - circuit short to battery or open
b1659-front fog lamp control circuit low
b165c-park lamp control circuit low
b165d-park lamp control circuit high
b165e-park lamp control circuit open
b1660-front fog lamp control circuit high
b1661-front fog lamp control circuit open
b1667-reverse lamp control circuit low
b1669-reverse lamp control circuit open
b168f-front fog lamp switch circuit stuck
b169c-cargo lamp switch stuck
b16a3-11-passenger window switch backlighting - circuit short to ground
b16a3-15-passenger window switch backlighting - circuit short to battery or open
b16b0-left stop lamp control circuit low
b16b2-left stop lamp control circuit open
b16b4-right stop lamp control circuit low
b16b6-right stop lamp control circuit open
b17ae-left trailer tow lamp control circuit low
b17b2-right trailer tow lamp control circuit low
b17e3-turn signal switch performance
b1800-2a-driver door lock/unlock switch - signal stuck in range
b1805-2a-passenger door lock/unlock switch - signal stuck in range
b1820-hood ajar input circuit high
b1853-11-driver window control - circuit short to ground
b1853-13-driver window control - circuit open
b1857-11-driver window position sensor power supply - circuit short to ground
b1857-15-driver window position sensor power supply - circuit short to battery or open - express motor only
b185a-31-driver window position sensor - no signal
b185e-11-passenger window control - circuit short to ground
b185e-13-passenger window control - circuit open
b1862-11-passenger window position sensor power supply - circuit short to ground
b1862-15-passenger window position sensor power supply - circuit short to battery or open - express motor only
b1865-31-passenger window position sensor - no signal
b18b5-00-master switch - front left window switch
b1910-2a-passenger window switch - signal stuck in range
b1a10-rke fob 1 battery low
b1a11-rke fob 2 battery low
b1a12-rke fob 3 battery low
b1a13-rke fob 4 battery low
b1a14-rke fob 5 battery low
b1a15-rke fob 6 battery low
b1a16-rke fob 7 battery low
b1a17-rke fob 8 battery low
b1a24-key not programmed
b1a25-invalid key
b1a26-maximum number of keys programmed
b1a27-skreem programming performance
b1a28-ecm mismatch with skim
b1a29-skim basestation mismatch
b1a35-unidentified key communication error
b1a6c-secret key mismatch
b1a77- remote start antenna circuit low
b1a79- remote start antenna circuit open or not connected
b1d04-2a-mirror adjust switch input - signal stuck in range
b1d08-11-driver mirror position sensor power supply - circuit short to ground
b1d0b-11-driver mirror vertical position sensor input - circuit short to ground
b1d0b-12-driver mirror vertical position sensor input - circuit short to battery
b1d0e-11-driver mirror horizontal position sensor input - circuit short to ground
b1d0e-12-driver mirror horizontal position sensor input - circuit short to battery
b1d11-11-passenger mirror position sensor power supply - circuit short to ground
b1d14-11-passenger mirror vertical position sensor input - circuit short to ground
b1d14-12-passenger mirror vertical position sensor input - circuit short to battery
b1d17-11-passenger mirror horizontal position sensor input - circuit short to ground
b1d17-12-passenger mirror horizontal position sensor input - circuit short to battery
b1d1e-11-driver mirror vertical motor control - circuit short to ground
b1d22-11-driver mirror horizontal motor control - circuit short to ground
b1d2a-11-passenger mirror vertical motor control - circuit short to ground
b1d2e-11-passenger mirror horizontal motor control - circuit short to ground
b1d32-11-driver mirror heater control - circuit short to ground
b1d32-15-driver mirror heater control - circuit short to battery or open
b1d36-11-passenger mirror heater control - circuit short to ground
b1d36-15-passenger mirror heater control - circuit short to battery or open
b1d4a-2a-memory switch input - signal stuck in range
b1d56-adjustable pedal sensor circuit low
b1d57-adjustable pedal sensor circuit high
b1d5b-adjustable pedal switch circuit performance
b1d5c-adjustable pedal switch circuit stuck forward
b1d5d-adjustable pedal switch circuit stuck rearward
b1d62-power seat switch stuck
b1d63-power seat switch open
b1d67-adjustable pedal control circuit performance
b1d68-adjustable pedal control circuit low
b1d6d-seat horizontal position sensor circuit low
b1d6e-seat horizontal position sensor circuit high
b1d71-seat front vertical position sensor circuit low
b1d72-seat front vertical position sensor circuit high
b1d75-seat rear vertical position sensor circuit low
b1d76-seat rear vertical position sensor circuit high
b1d79-seat recliner position sensor circuit low
b1d7a-seat recliner position sensor circuit high
b1d7b-seat horizontal motor control circuit performance
b1a25-invalid key
b1d7f-seat front vertical motor control circuit performance
b1d83-seat rear vertical motor control circuit performance
b1d87-seat backrest motor control circuit performance
b1d9b-seat horizontal front stop not learned
b1e64-00-left mirror select switch stuck
b1e65-00-right mirror select switch stuck
b1e99-11-front left heater control circuit - circuit short to ground
b1e99-12-front left heater control circuit - circuit short to battery
b1e99-13-front left heater control circuit - circuit open
b1e99-1e-front left heater control circuit - circuit resistance out of range
b1e9a-11-front right heater control circuit - circuit short to ground
b1e9a-12-front right heater control circuit - circuit short to battery
b1e9a-13-front right heater control circuit - circuit open
b1e9a-1e-front right heater control circuit - circuit resistance out of range
b1e9b-11-rear left heater control circuit - circuit short to ground
b1e9b-12-rear left heater control circuit - circuit short to battery
b1e9b-13-rear left heater control circuit - circuit open
b1e9b-1e-rear left heater control circuit - circuit resistance out of range
b1e9c-11-rear right heater control circuit - circuit short to ground
b1e9c-12-rear right heater control circuit - circuit short to battery
b1e9c-13-rear right heater control circuit - circuit open
b1e9c-1e-rear right heater control circuit - circuit resistance out of range
b1e9d-11-front left vent control circuit - circuit short to ground
b1e9d-12-front left vent control circuit - circuit short to battery
b1e9d-13-front left vent control circuit - circuit open
b1e9e-11-front right vent control circuit - circuit short to ground
b1e9e-12-front right vent control circuit - circuit short to battery
b1e9e-13-front right vent control circuit - circuit open
b1eb1-1a-front left seat heater sensor - circuit resistance below threshold
b1eb1-1b-front left seat heater sensor - circuit resistance above threshold
b1eb2-1a-front right seat heater sensor - circuit resistance below threshold
b1eb2-1b-front right seat heater sensor - circuit resistance above threshold
b1eb3-1a-rear left seat heater sensor - circuit resistance below threshold
b1eb3-1b-rear left seat heater sensor - circuit resistance above threshold
b1eb4-1a-rear right seat heater sensor - circuit resistance below threshold
b1eb4-1b-rear right seat heater sensor - circuit resistance above threshold
b2104-ignition run/start control circuit low
b210a-84-system voltage low - signal below allowable range
b210b-85-system voltage high - signal above allowable range
b210c-16-battery voltage input - circuit voltage below threshold
b210c-16-battery voltage input-circuit voltage below threshold
b210c-17-battery voltage input - circuit voltage above threshold
b210c-17-battery voltage input-circuit voltage above threshold
b210c-18-battery voltage input - circuit below threshold
b210d-84-battery voltage low - signal below allowable range
b210d-battery voltage low
b210e-85-battery voltage high - signal above allowable range
b210e-battery voltage high
b2112-5-volt supply circuit low
b2113-5 volt supply circuit high
b2122-ignition run control 1 circuit low
b2128-16-sensor supply voltage-circuit voltage below threshold
b2128-17-sensor supply voltage-circuit voltage above threshold
b2129-16-pts display supply voltage-circuit voltage below threshold
b2142-ignition off draw (iod) fuse not present
b2148-ignition run control 2 circuit low
b2184-ignition unlock/run/start control circuit low
b21a1-00-ecu reset/recovery occurred
b21a1-ecu reset/recovery occurred
b21dd-84-system voltage - signal below allowable range
b21dd-85-system voltage - signal above allowable range
b2202-eeprom checksum performance
b2204-ecu configuration mismatch
b2205-original vin missing/mismatch
b2206-current vin missing/mismatch
b2214-00-(hvac) climate control internal
b2215-front control module internal (totally integrated power module)
b221a-00-(hsm) heated seat module internal
b221c-memory seat module internal
b221e-radio internal
b221f-amplifier internal
b222a-00-vehicle line mismatch
b222a-vehicle line mismatch
b222b-vehicle entertainment system internal
b222c-vehicle configuration not programmed
b2232-00-(pts) parktronics internal
b2234-00-(pts) parktronics rear display internal
b2287-satellite video receiver internal
b2301-wiper mode switch input circuit low
b2304-wiper park switch input circuit low
b2305-wiper park switch input circuit high
b2307-washer switch input circuit low
b2313-wiper on/off control circuit low
b2315-wiper on/off control circuit open
b2318-wiper high/low control circuit high
b2339-horn switch stuck - with evic
b2339-horn switch stuck - without evic
b238e-hi beam switch circuit low
b2390-mist switch circuit low
b2394-flash to pass / optical horn switch circuit stuck
b2598-54-door module front left - missing calibration - quad/crew cab only
b2598-96-door module front left - component internal failure
b2599-54-door module front right - missing calibration - quad/crew cab only
b2599-96-door module front right - component internal failure
b282e-11-driver puddle lamp control - circuit short to ground
b282e-15-driver puddle lamp control - circuit short to battery or open
b282f-11-passenger puddle lamp control - circuit short to ground
b282f-15-passenger puddle lamp control - circuit short to battery or open
c0077- low tire pressure
c1000-brake pedal switch 1 circuit performance
c1008-brake fluid level circuit high
c1009-brake fluid level low
c100a-left front wheel speed sensor circuit
c1011-left front wheel speed sensor signal erratic performance
c1014-left front wheel speed comparative performance
c1015-right front wheel speed sensor circuit
c101c-right front wheel speed sensor signal erratic performance
c101f-right front wheel speed comparative performance
c1020-left rear wheel speed sensor circuit
c1027-left rear wheel speed sensor signal erratic performance
c102a-left rear wheel speed comparative performance
c102b-right rear wheel speed sensor circuit
c1032-right rear wheel speed sensor signal erratic performance
c1035-right rear wheel speed comparative performance
c104c-left front inlet valve control circuit low
c1050-right front inlet valve control circuit low
c1054-left rear inlet valve control circuit low
c1058-right rear inlet valve control circuit low
c1060-left front outlet valve control circuit low
c1064-right front outlet valve control circuit low
c1068-left rear outlet valve control circuit low
c106c-right rear outlet valve control circuit low
c1073-abs motor control circuit
c1078-tire revolutions range performance
c1079-tone wheel teeth count range performance
c107b-wheel speed comparative performance
c107d-brake pedal switch 1/2 correlation
c1086-abs system control too long
c1090-abs brake lamp control circuit low
c1091-abs brake lamp control circuit high
c1201-front traction control inlet valve control circuit low
c1205-rear traction control inlet valve control circuit low
c1209-front traction control prime valve control circuit low
c120d-rear traction control prime valve control circuit low
c1213-g sensor input signal stuck
c1219-steering angle sensor erratic performance
c121c-torque request signal denied
c121d-brake pressure sensor circuit
c121e-brake pressure sensor comparative performance
c1231-drive test: Steering angle sensor
c1232-drive test: Pressure sensor
c1234-drive test: Sensor cluster installation
c1235 drive test: Test active
c1238-drive test: Unsuccessful
c1239-emission rolls test active
c123a-esp system sensors calibration
c123b-esp system control too long
c123f-steering angle sensor comparative performance
c1240-steering angle sensor overtravel performance
c1242-g sensor input signal performance
c1243-g sensor not initialized
c1401-transfer case range select switch circuit low
c1402- transfer case range select switch circuit high
c1403-transfer case range position sensor performance
c1404-transfer case range position sensor circuit low
c1405-transfer case range position sensor circuit high
c1406-transfer case brake performance
c1407-transfer case brake control circuit low
c1408-transfer case brake control circuit high
c140a-transfer case motor performance
c140d-transfer case motor control circuit open
c140e-transfer case motor blocked
c140f-transfer case range position sensor erratic performance
c1415-transfer case motor current performance
c1438-transfer case differential clutch worn
c1444-transfer case motor overuse
c1464-front axle disconnect control circuit low
c1465-front axle disconnect control circuit high
c1472-transfer case clutch control circuit performance
c1477-transfer case clutch over temperature
c147b-front axle disconnect sensor circuit performance
c1501-tire pressure sensor 1 internal
c1502-tire pressure sensor 2 internal
c1503-tire pressure sensor 3 internal
c1504-tire pressure sensor 4 internal
c151c-tire pressure monitoring (tpm) sensors missing
c2100-battery voltage low
c2101-battery voltage high
c2105-abs valve supply voltage circuit low
c2111-sensor supply 1 voltage circuit low
c2112-sensor supply 1 voltage circuit high
c2200-anti-lock brake module internal
c2201-(dtcm) drive train control internal
c2202-original vin mismatch / missing
c2204-dynamics sensor internal
c2205-steering angle sensor internal
c2206-vehicle configuration mismatch
c230a-neutral indicator control circuit low
c230b- neutral indicator control circuit high
c2312-trac/esp off switch stuck
p000b-bank 1 camshaft 2 position slow response
p0013-bank 1 camshaft 2 position actuator circuit open
p0014-exhaust target error bank 1
p0016-crankshaft/camshaft timing misalignment
p0031-o2 sensor 1/1 heater circuit low
p0032-o2 sensor 1/1 heater circuit high
p0037-o2 sensor 1/2 heater circuit low
p0038-o2 sensor 1/2 heater circuit high
p0051-o2 sensor 2/1 heater circuit low
p0052-o2 sensor 2/1 heater circuit high
p0057-o2 sensor 2/2 heater circuit low
p0058-o2 sensor 2/2 heater circuit high
p0071-ambient air temperature sensor performance
p0072-ambient air temperature sensor circuit low
p0073-ambient air temperature sensor circuit high
p0107-manifold absolute pressure sensor circuit low
p0108-manifold absolute pressure sensor circuit high
p0111-intake air temperature sensor rationality
p0112-intake air temperature sensor circuit low
p0113-intake air temperature sensor circuit high
p0116-engine coolant temperature sensor circuit performance
p0117-engine coolant temperature sensor circuit low
p0118-engine coolant temperature sensor circuit high
p0121-throttle position sensor 1 performance
p0122-throttle position sensor 1 circuit low
p0122-tps/app circuit low
p0123-throttle position sensor 1 circuit high
p0123-tps/app circuit high
p0124-tps/app intermittent
p0125-insufficient coolant temp for closed-loop fuel control
p0128-thermostat rationality
p0129-barometric pressure out-of-range low
p0131-o2 sensor 1/1 circuit low
p0132-o2 sensor 1/1 circuit high
p0133-o2 sensor 1/1 slow response
p0135-o2 sensor 1/1 heater performance
p0137-o2 sensor 1/2 circuit low
p0138-o2 sensor 1/2 circuit high
p0139-o2 sensor 1/2 slow response
p013a-o2 sensor 1/2 slow response - rich to lean
p013c-o2 sensor 2/2 slow response - rich to lean
p0141-o2 sensor 1/2 heater performance
p0151-o2 sensor 2/1 circuit low
p0152-o2 sensor 2/1 circuit high
p0153-o2 sensor 2/1 slow response
p0155-o2 sensor 2/1 heater performance
p0157-o2 sensor 2/2 circuit low
p0158-o2 sensor 2/2 circuit high
p0159-o2 sensor 2/2 slow response
p0161-o2 sensor 2/2 heater performance
p0171-fuel system 1/1 lean
p0172-fuel system 1/1 rich
p0174-fuel system 2/1 lean
p0175-fuel system 2/1 rich
p0196-engine oil temperature sensor performance
p0197-engine oil temperature sensor circuit low
p0198-engine oil temperature sensor circuit high
p0201-fuel injector 1 circuit
p0202-fuel injector 2 circuit
p0203-fuel injector 3 circuit
p0204-fuel injector 4 circuit
p0205-fuel injector 5 circuit
p0206-fuel injector 6 circuit
p0207-fuel injector 7 circuit
p0208-fuel injector 8 circuit
p0218-high temperature operation activated
p0221-throttle position sensor 2 performance
p0222-throttle position sensor 2 circuit low
p0223-throttle position sensor 2 circuit high
p0298-engine oil temperature too high
p0300-multiple cylinder misfire
p0301-cylinder 1 misfire
p0302-cylinder 2 misfire
p0303-cylinder 3 misfire
p0304-cylinder 4 misfire
p0305-cylinder 5 misfire
p0306-cylinder 6 misfire
p0307-cylinder 7 misfire
p0308-cylinder 8 misfire
p0315-no crank sensor learned
p0325-knock sensor 1 circuit
p0330-knock sensor 2 circuit
p0335-crankshaft position sensor circuit
p0339-crankshaft position sensor intermittent
p0340-camshaft position sensor circuit
p0344-camshaft position sensor intermittent
p0401-egr system performance
p0403-egr solenoid circuit
p0404-egr position sensor performance
p0405-egr position sensor circuit low
p0406-egr position sensor circuit high
p0420-catalyst efficiency (bank 1)
p0430-catalyst efficiency (bank 2)
p0440-general evap system failure
p0441-evap purge system performance
p0443-evap purge solenoid circuit
p0452-evap pressure switch stuck closed
p0455-evap purge system large leak
p0456-evap purge system small leak
p0457-loose fuel cap
p0461-fuel level sensor 1 performance
p0462-fuel level sensor 1 circuit low
p0463-fuel level sensor 1 circuit high
p0480-cooling fan 1 control circuit
p0501-vehicle speed sensor 1 performance
p0503-vehicle speed sensor 1 erratic
p0506-idle speed performance lower than excepted
p0507-idle speed performance higher than excepted
p050b-cold start ignition timing performance
p050d-cold start rough idle
p0513-invalid skim key
p0520-engine oil pressure sensor circuit
p0521-engine oil pressure sensor performance
p0522-engine oil pressure sensor circuit low 5.7l
p0522-oil pressure too low 3.7l, 4.7l
p0523-engine oil pressure sensor circuit high
p0524-engine oil pressure too low
p0532-a/c pressure sensor circuit low
p0533-a/c pressure sensor circuit high
p0562-battery voltage low
p0563-battery voltage high
p0571-brake switch 1 performance
p0572-brake switch 1 stuck on
p0573-brake switch 1 stuck off
p0579-speed control switch 1 performance
p0580-speed control switch 1 circuit low
p0581-speed control switch 1 circuit high
p0585-speed control switch 1/2 correlation
p0591-speed control switch 2 performance
p0592-speed control switch 2 circuit low
p0593-speed control switch 2 circuit high
p0600-serial communication link
p0601-internal memory checksum invalid
p0602-control module programming error/not programmed
p0604-internal control module ram
p0605-internal control module rom
p0606-internal control processor
p0606-internal ecm processor
p060b-etc a/d ground performance
p060d-etc level 2 app performance
p060e-etc level 2 tps performance
p060f-etc level 2 ect performance
p0613-internal transmission processor
p0615-starter relay control circuit open - ngc
p061a-etc level 2 torque performance
p061c-etc level 2 rpm performance
p0622-generator field control circuit
p0627-fuel pump control circuit
p062c-etc level 2 mph performance
p0630-vin not programmed in pcm
p0632-odometer not programmed in pcm
p0633-skim key not programmed in pcm
p063a-generator voltage sense circuit
p0642-sensor reference voltage 1 circuit low
p0643-primary 5-volt supply circuit high
p0645-a/c clutch control circuit
p0652-sensor reference voltage 2 circuit low
p0653-sensor reference voltage 2 circuit high
p0685-auto shutdown control circuit
p0688-auto shutdown sense circuit low
p0691-cooling fan 1 control circuit low
p0692-cooling fan 1 control circuit high
p0693-cooling fan 2 control circuit low
p0694-cooling fan 2 control circuit high
p0700-transmission control system (mil request)
p0703-brake switch 2 performance
p0706-transmission range sensor rationality
p0711-transmission temperature sensor performance
p0712-transmission temperature sensor low
p0713-transmission temperature sensor high
p0714-transmission temperature sensor intermittent
p0716-input speed sensor 1 circuit performance
p0721-output speed sensor circuit performance
p0726-engine speed input circuit range/performance
p0731-gear ratio error in 1st
p0732-gear ratio error in 2nd
p0733-gear ratio error in 3rd
p0734-gear ratio error in 4th
p0735-gear ratio error in 5th
p0736-gear ratio error in reverse
p0740-tcc out of range
p0750-lr solenoid circuit
p0755-2/4 solenoid circuit
p0755-2c solenoid circuit
p0760-od solenoid circuit
p0765-ud solenoid circuit
p0770-4c solenoid circuit
p0838-four wheel drive (4wd) switch circuit low
p0839-four wheel drive (4wd) switch circuit high
p0841-lr pressure switch rationality
p0845-2/4 hydraulic pressure test
p0845-2c hydraulic pressure test
p0846-2/4 pressure switch rationality
p0846-2c pressure switch rationality
p0850-park/neutral switch performance
p0853-overdrive / tow switch input circuit stuck
p0868-line pressure low
p0869-line pressure high
p0870-od hydraulic pressure test
p0871-od pressure switch rationality
p0875-ud hydraulic pressure test
p0876-ud pressure switch rationality
p0882-tcm power input low
p0883-tcm power input high
p0884-power up at speed
p0890-switched battery
p0897-transmission fluid deteriorated
p0933-hydraulic pressure sensor range/performance
p0934-line pressure sensor circuit low
p0935-line pressure sensor circuit high
p0944-loss of hydraulic pump prime
p0957-autostick circuit low (ers)
p0958-autostick circuit high (ers)
p0987-4c hydraulic pressure test
p0988-4c pressure switch rationality
p0992-2/4/od hydraulic pressure test
p1004-short runner valve control performance
p1103-dc to ac converter switch stuck
p1115-general temperature rationality
p1128-closed loop fueling not achieved - bank 1
p1129-closed loop fueling not achieved - bank 2
p1239-engine oil temperature too low
p1272-a/c clutch control circuit 2 low
p1273-a/c clutch control circuit 2 high
p127c-fuel pump control circuit 2 low - ngc
p127e-fuel pump control circuit 2 open - ngc
p128b-tcm power control circuit 2 low - 42rle
p128b-tcm power control circuit 2 low - 45/545rfe
p128c-tcm power control circuit 2 high - 42rle
p128c-tcm power control circuit 2 high - 45/545rfe
p128d-tcm power control circuit 2 open - 42rle
p128d-tcm power control circuit 2 open - 45/545rfe
p128e-tcm power control circuit 2 overcurrent - 42rle
p128e-tcm power control circuit 2 overcurrent - 45/545rfe
p129c-inverter control circuit high
p129e-inverter control circuit overcurrent
p1404-egr position sensor rationality closed
p1411-cylinder 1 reactivation control performance
p1414-cylinder 4 reactivation control performance
p1416-cylinder 6 reactivation control performance
p1417-cylinder 7 reactivation control performance
p1521-incorrect engine oil type
p1524-oil pressure out of range - camshaft advance/retard disabled
p1572-brake pedal stuck on
p1573-brake pedal stuck off
p1593-speed control switch 1/2 stuck
p1607-pcm internal shutdown timer slow rationality
p1618-sensor reference voltage 1 circuit erratic
p1628-sensor reference voltage 2 circuit erratic
p1684-battery was disconnected
p1696-eeprom memory write denied/invalid
p1697-emr (sri) mileage not stored
p1713-restricted manual valve in t2 range
p1715-restricted manual valve in t3 range
p1736-gear ratio error in 2nd prime
p1745-transmission line pressure too high for too long
p1775-solenoid switch valve latched in tcc position
p1776-solenoid switch valve latched in lr position
p1790-fault immediately after shift
p1794-speed sensor ground error
p1797-manual shift overheat
p2008-short runner valve (srv) control circuit
p2016-short runner valve (srv) position sensor circuit low
p2017-short runner valve (srv) position sensor circuit high
p2072-electronic throttle control system - ice blockage
p2096-downstream fuel trim system 1 lean
p2097-downstream fuel trim system 1 rich
p2098-downstream fuel trim system 2 lean
p2099-downstream fuel trim system 2 rich
p2100-electronic throttle control motor circuit
p2101-electronic throttle control motor performance
p2107-electronic throttle control module processor
p2110-electronic throttle control - forced limited rpm
p2111-electronic throttle control - unable to close
p2112-electronic throttle control - unable to open
p2115-accelerator pedal position sensor 1 minimum stop performance
p2116-accelerator pedal position sensor 2 minimum stop performance
p2118-electronic throttle control motor circuit
p2122-accelerator pedal position sensor 1 circuit low
p2123-accelerator pedal position sensor 1 circuit high
p2127-accelerator pedal position sensor 2 circuit low
p2128-accelerator pedal position sensor 2 circuit high
p2135-throttle position sensor 1/2 correlation
p2138-accelerator pedal position sensor 1/2 correlation
p2161-vehicle speed sensor 2 erratic
p2166-accelerator pedal position sensor 1 maximum stop performance
p2167-accelerator pedal position sensor 2 maximum stop performance
p2172-high airflow/vacuum leak detected (instantaneous accumulation)
p2173-high airflow/vacuum leak detected (slow accumulation)
p2174-low airflow/restriction detected (instantaneous accumulation)
p2175-low airflow/restriction detected (slow accumulation)
p2181-cooling system performance
p2271-o2 sensor 1/2 signal stuck rich
p2273-o2 sensor 2/2 signal stuck rich
p2299-brake pedal position/accelerator pedal position incompatible
p2302-ignition coil 1 secondary circuit- insufficient ionization
p2305-ignition coil 2 secondary circuit- insufficient ionization
p2308-ignition coil 3 secondary circuit- insufficient ionization
p2311-ignition coil 4 secondary circuit- insufficient ionization
p2314-ignition coil 5 secondary circuit- insufficient ionization
p2317-ignition coil 6 secondary circuit- insufficient ionization
p2320-ignition coil 7 secondary circuit- insufficient ionization
p2323-ignition coil 8 secondary circuit- insufficient ionization
p2503-charging system output low
p2504-charging system output high
p2610-pcm internal shutdown timer fast rationality
p2700-inadequate element volume lr
p2701-inadequate element volume 2c
p2702-inadequate element volume od
p2703- inadequate element volume ud
p2704-inadequate element volume 4c
p2706-ms solenoid circuit
p3400-mds rationality bank 1
p3401-mds solenoid 1 circuit
p3402-cylinder 1 deactivation control performance
p3425-mds solenoid 4 circuit
p3426-cylinder 4 deactivation control performance
p3441-mds solenoid 6 circuit
p3442-cylinder 6 deactivation control performance
p3449-mds solenoid 7 circuit
p3450-cylinder 7 deactivation control performance
p3497-mds rationality bank 2
u0001-can c bus
u0001-can c bus
u0001-can c bus circuit
u0002-can c bus off performance
u0010-00-can interior bus
u0010-can interior bus
u0011-00-can b bus performance
u0011-can interior bus off performance
u0014-can interior bus (+) circuit high
u0016-can interior bus (-) circuit low
u0019-can b bus
u0037-11-lin bus - circuit short to ground
u0100-lost communication with ecm/pcm
u0100-lost communication with the ecm/pcm
u0101-lost communication with tcm
u0114-lost communication with final drive control module (drivetrain control module)
u0121-lost communication with abs
u0121-lost communication with anti-lock brake module
u0125-lost communication with dynamics sensor
u0126-lost communication with sas
u0126-lost communication with steering angle sensor
u0141-00-lost communication with ipm (fcm/tipm)
u0141-lost communication with front control module
u0141-lost communication with ipm (fcm/tipm)
u0151-lost communication with occupant restraint controller (orc)
u0151-lost communication with orc
u0155-00-lost communication with cluster/ccn
u0155-lost communication with cluster/ccn
u0159-lost communication with parking assist control module
u0159-lost communication with parking assist control module (pts)
u0161-lost communication with compass module
u0164-00-lost communication with hvac control module
u0164-lost communication with hvac control module
u0168-lost communication with vehicle security control module (win)
u0168-lost communication with vehicle security control module (wireless ignition node or win)
u0001-can c bus
u0001-can c bus
u0019-can b bus
u0168-lost communication with vehicle security control module (wireless ignition node)
u0184-lost communication with radio
u0186-lost communication with audio amplifier (amp)
u0196-lost communication with vehicle entertainment control module
u0197-lost communication with hands free phone module
u0197-lost communication with hands free phone module (hfm)
u0203-00-lost communication with door module front left
u0203-lost communication with door module front left
u0203-lost communication with left front door module (dmfl) (driver door module)
u0203-lost communication with left front door module (dmlf) (driver door module)
u0204-00-lost communication with door module front right
u0204-lost communication with door module front right
u0204-lost communication with right front door module (dmfr) (passenger door module)
u0204-lost communication with right front door module (dmrf) (passenger door module)
u0208-lost communication with heated seat control module
u0208-lost communication with heated seat module (hsm)
u0209-00-lost communication with memory seat control module
u0209-lost communication with memory seat control module
u0209-lost communication with memory seat control module (msmd)
u0212-lost communication with scm (sas)
u0249-lost communication with vehicle entertainment control module - last row (ves3)
u0401-implausible data received from ecm
u0401-implausible data received from ecm/pcm
u0402-implausible data received from tcm
u0415-implausible data received from abs
u0423-00-implausible data received from cluster/ccn
u0429-implausible data received from scm (sas)
u1003-esp can c bus performance
u1004-can c bus transmit performance
u1008-lin 1 bus
u1101-00-lost communication with pts display-rear 1
u1109-lost communication with lin steering wheel controls
u110c-no fuel level bus message received
u110e-lost ambient temperature message
u1110-lost vehicle speed message
u1113-lost a/c pressure message
u1120-lost wheel distance message
u113d-lost communication with master power window switch
u1147-additional can interior bus ecu detected
u1148-additional can c bus ecu detected
u1149-lost communication with multi-function switch
u1158-lost communication with satellite video receiver (sdarv)
u1191-lost communication with upper switch bank
u1192-lost communication with lower switch bank
u1197-security seed response not received from ecm/pcm
u1403-implausible fuel level signal received
u1412-implausible vehicle speed signal received
u1417-implausible left wheel distance signal received
u1418-implausible right wheel distance signal received
u1446-00-implausible heated steering wheel temperature message received (ccn)
u1008-lin 1 bus
