Fuel economy difference between Ram 2500 Hemi and Cummins?
#31
wheres the moderator??? this is my first time back on here in a while, and seriously, wtf is with everyone? the guy asked the mpg. we have people chiming in with their 3rd gens, their this, their that. if you dont own a 4th gen 2500, you shouldnt even be talking.
my 2010 2500 gets $h!t gas mileage. usually 15/16 hwy and then city is anyones guess.
If I had the money when I bought my truck, I would have spent the extra on the cummins, but 10 grand was not available, ha. But you can find some decent deals. One guy I ran into said he was getting 18 city and 22 hwy with his cummins.
#32
evan, was year was your diesel? One guy I talked to was in a lifted 06-09, and then the other guy was a 4th gen 2500, and they both said they are getting way more than me city, and slightly better highway.
When I was buying my truck, everyone on here dissuaded me from diesel saying the only time I was going to get better mpgs was when I was towing. Only now when I get the chance to talk to anyone in a cummins, they say they are getting better mpgs.
#33
The only way you will get better mpg is if you delete the emissions system on the 6.7. Which I ended up doing and I got about 19 mpg hwy and 13-14 towing my fifth wheel. Not long after that my clutch and flywheel went out, and then my G56 tranny went. Guess what no warranty because my truck was deleted and had just over 36K miles on it. I traded it off for the hemi and don't regret it one bit. I owned several 5.9 cummins trucks before this and loved them all. All of them got 18 - 20 mpg hwy and 13 - 14 towing, and they never had any issues with over 100K miles on them.
#34
I'll jump in. Mine is a 2011 2500 club cab 4X4, hemi, 4.10 gears. I'll typically get 12-13 going to work and back...mostly 25-30 mph with 2 miles of highway at 60 mph. Unloaded highway I can get 16-17, but there are some variables there that I'll hit in a minute.
Towing a car hauler (about 5500-6000 pounds) with another 1200 pounds of stuff in the truck from sea level in CA to 6500 ft in CO, I averaged 12.5 mpg, with speeds in the 65-70 mph range.
Variables: I've learned a couple things. My highway mileage drops to about 12-13 if I'm cruising at 75 mph and running the 10-15% ethanol blend...drop to 65 with ethanol and I'm back in the 16 mpg range. Add a 1-2 mpg for pure gas. So speed and fuel are both huge variables. Along those lines, headwinds will kill mileage too...driving from 6500 ft in CO back to CA sea level with a motorcycle in the back and a 30 mph headwind for all but the last 100 miles netted me 12.5 mpg, with speeds generally around 70, and that was all with 10-15% ethanol. Temperature is another variable. I consistently get 1 mpg less if it is cold outside (40-ish degrees and lower). If it is in the low 40's in the morning with highs above that, and my mileage improves.
Also keep in mind that I've got Goodyear DuraTracs on my truck...not really the best tire for good MPG, but phenomenal in the snow & ice.
For the PowerWagon, you have to remember that it weighs a few hundred pounds more than the regular 2500 hemi, and it's revving higher on the highway due to the tighter gears...the gearing is partially cancelled out by the taller tires, but you'll still be revving a 200-300 rpm higher in the PowerWagon vs a regular 2500 with the 4.10 gears.
#35
i guess I should have mentioned my mpgs when i was stock, which was only the drive home from the dealer in ny, I averaged 19 mpgs, there was even times it was in the low 20s but that was at like 65 the entire way.
#36
#37
damn man, thats pretty bad. your going about the same as me, and I'm running on much bigger tires and a small lift.
#38
#39
5.9L, Cummins was doing it right. To bad that engine wasnt a option in the new heavy duties
