Tire size
Old 07-23-2015, 10:53 PM
13ram1500's Avatar
13ram1500
13ram1500 is offline
Default Tire size
Hey guys I have a 2013 ram 1500 4x4 cc 5.7l
I'm wanting to get a lift for it and tires and wheels and all that good stuff. My question is what tire size should I go with? I have 3.55 gear ratio should I go with 35s or can I get away with 37s. I do not normally tow anything.
Old 07-23-2015, 11:12 PM
jkeaton is offline
Dodge Forum Administrator
Size of the tires depends on how much lift you get. Can't tell tire size till you know how high you're going.
Old 07-23-2015, 11:15 PM
13ram1500's Avatar
13ram1500
Default Tire size
I get that but what I'm saying is I need to know if I need to get 35s or if I can get away with getting 37s. If I have to get 35s then I'll get a 4 inch lift. If I can get away with 37s I'll get a 6 inch lift. I need to know what size tire to run before I get a lift. I'm not going to get a 6 inch lift just for 35s and vise versa with the 37s. Now do I need to run 35s or can I run 37s? I do not tow anything or really haul much.
Old 07-24-2015, 07:23 AM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
You can run whatever size tire you want, but the bigger the tire, the more wear on the front end components plus the greater the rolling resistance.
First off, I would never run 35's on 3.55 gears let alone 37s. I thought my 1500 wouldn't get out of its own
way with stock 3.92 gears when I went to 35s and immediately went to 4.56 gears. I'm sure some guys will disagree, but I've got 25 years of driving lifted trucks under my belt, and IMO minimum 4.10 gears with
35s, 4.56 with 37s.
Then you need to address how your truck is going to be used. Are you doing this just to park at the junior high to pick up chicks or are you actually going to use your truck as a truck? Because with the former, you can stuff in as much tire as can fit. With the latter, you'll want to retain as much stock travel as you can or even increase it.
In my case, when I had my 1500, I used my truck to tow a bass boat for tournaments, used the bed for hauling river rock, threw in the occasional deer or hog and put my ATV in the bed. I couldn't go too high or my truck wouldn't be functional.
Old 07-24-2015, 08:26 AM
jkeaton is offline
I wanna pick up chicks......
Old 07-24-2015, 08:36 AM
HammerZ71's Avatar
HammerZ71
This was my 1500, 4" of lift with full sub frame for strength. You'll note even with 35s there is plenty of room for suspension travel.
Old 07-24-2015, 12:00 PM
13ram1500's Avatar
13ram1500
Default Tire size
It looks good man. So I wouldn't be able to run the 35s an 4 inch lift very good? I mean it has 33s from the factory on it and it pulls them good is why I'm asking
Quick Reply: Tire size
