Led light bar behind front grill
on
http://www.autoanything.com/lights/r...bar-mount-kits
Makes life easy for those not into fabrication...
I was able to mount 2 8" LED light bar's behind the grill. Went with the 2 instead of one due to the fact that the center portion of the grill assembly would have blocked some of the LED's. Mounted the lights on the lower frame assembly for two reasons: 1) The upper grill support is not level, has somewhat of a curve to it, could be a pain in fabricating mounting and 2) Tennessee has a 42" height law, meaning that the lights cannot be mounted more than 42" above the level of the ground, (read that on the Tennessee Code.
