Let me introduce myself..
If he mounted it the same way I did then here's how. I popped that plastic insert in between the fog lights out. Then you will see 2 metal brackets one on each side connected to the frame. I drilled a hole in each one and bolted the light bar in. The one I got was 30"s long. You may can get away with a 32" I'm not sure. In all took me about a hour an a half to mount it and wire it up.
