Rain drops falling on my head. Sunroof leak?
I have had this problem!!!!
OK this is my first day here and I might be able to help. I worked at a dealership that had a TON of Pollen and my Demo started to leak from the sunroof.... I got a lesson from the Service department that day. The Sunroof will usually have 2 lines that run down the A pillar and out through the bottom of the car. Those lines are designed to help drain any moisture that may get through the sunroof... Problem is these holes can also get clogged by sticks, pollen, leaf depris... you name it. usually can be cleared with a vacum or high pressured air. Good Luck
Thanks for the information. I will pass on to the service guy at the dealership. Of course he does not need me to tell him how to do the job. I just want my truck back.
How big are these lines, would'nt think that massive amounts of pollen would do this? I guess it is like paste after getting wet. Do I have this to look forward to every year?
I have my truck back home.
First let me say thanks to those who gave advice, I appreciate it. I picked up my truck today. After speaking with the mechanic there, he told me the line/hose was crimped. He said this was done at the factory, but he fixed it after removing the headliner. He told me I should not experience this problem in the future. I sure hope he is right.
leaking sunroof
I too have a 2009 Laramie with a leaking sunroof. Same symptoms. Took it back to the dealer for the third time and this time they told me that Chrysler was aware of the issue, but they did not have a solution. The first time they had it, they soaped the top and turned on the A/C fan to high--bubbles formed all around the seal. Interestingly, you can tell when it will happen. It's as if the gasket does not seal. In that case the wind noise and air flow are pronounced in the top of the vehicle. When it does seal (not completely but better than some times) the sunroof is less noisy and does not leak into the A pillar nor the overhead console.
This is not my first sunroof so I have a little background with what to expect. My previous was a GrandCherokee and it never leaked. I still have it--great second car with almost 300,000 miles on it.
On the Laramie you can take a business card and slide it down between the roof and the gasket and experience no resistance what-so-ever. On the old Jeep you will not get a business card to slide in.
I am waiting to see if Chrysler gets a fix soon. About ready to duck tape it to keep the noise, whistle and rain out until they come up with a solution.
I was experiencing the same thing on my Laramie only on the drivers side A pillar. After someone else told me to chack the drain line, sure enough I could see that it was not draining the water that accumulated in the sunroof channel. I blew it out today with compressed air and now it seems to work just fine. You can test it by opening the sunroof and pouring some water into the plastic channel in the front of the sunroof. After I blew it out, the water would run straight into the drain tube and come out the opening inside the door hinge (about 1/2 way down the door -rubber valve thing).
