iPod Integration Cable
#33
#36
Found a thread here with several good pictures of the installation and the soft buttons that are activated when you plug in an iPod/iPhone.
https://dodgeforum.com/forum/4th-gen-ram/200971-ipod-interface-cable-install-for-rer-short-review.html
OK, no idea why the link isn't working. For some reason it tries to find the thread outside of the 4th Gen forum. Just copy and past it into your browser.
#38
It'll probably be the same since both will sort off of the MP3's ID3 tags. So, if the song tagging is correctly done they should be the same.
I'm going to install a cable, just so I don't have to worry about loading new songs/albums into two places, MyGiG and my iPhone. I can just put the new music on my iPhone and not have to worry about loading it into the radio. Of course by just using the phone I'll only have 16GB of space as opposed to the radio's 30GB.
#39
#40
jvcougar;
I have looked under my dash behind the glove box and I can not for the life of me find the cover on the side of the dash that houses the module. Is there a picture anywhere, I'm sure it's there and I'm just blind. Thanks
Since you have the REN, your going to need the module changed out. When you open the front passenger door, there is a cover on the side of the dash, even with the glovebox. The module is in here. It should be part #5064762AC. You'll need to order part #5064449AF to run the Ipod cable (part #8221853) and activate the Ipod soft buttons on your radio.
Here's the kicker....module #5064449AF is only a mere $350 from your dealer.
