Last edit by: IB Advertising
Browse all: Interior Guides
- Dodge Ram 2009-Present: How to Replace Smart Key Battery
Step by step intructions for the do-it-yourself repairs.
For those who's key fob stops working....
#31
I switched my FOB with my extra and it still happens. I usually sit in my truck after I shut it off until the radio shuts off, then open the doors (i like to listen to the end of whatever song is on), and im going to see if that has anything to do with it. Going to avoid staying in the truck to long and see if that helps.
#32
This happens to me every other day and it's scarier when I don't hear the horn when I am trying to lock the truck remotely. Most of the time it comes around.
When I am trying to unlock it, and it fails. I'll push the lock button, hear it lock, then hit unlock and it works. I've tried both fobs, I am at the dealer today and they are performing software updates, but it's nothing related to this.
I do have and use remote start all the time. I hope someone finds a solution.
#33
I've got the problems too. Not sure why Dodge techs/shops have not heard of this, at least where I live. Seems llike plenty of us have the same issues. I know next time it goes in it will be looked at. Last time it went in, the dealer was closing and wouldn't look at it. Closing as in forever....
#34
#35
I think that it has to do with the receiver itself. I changed batteries just to see and it was better, at least it seemed that way. I thinks the FOB is directional and unless you point it right at the truck, it doesn't "all" the signal. I tested this by doing the down feature for the windows. Once you see the windows start to go down, point the FOB down, or block it with your hand. The windows stop going down. Also, it appears to depend on which side of the truck I'm on. I determined that as I walk to the truck from the front toward the driver's side it works every time.
I'd be willing to bet that the egineers were aware of a "problem" and decided that the driver would most likely back the truck into a parking spot, as I think most who have a truck do (to show off how well they can manuver the large vehicle of course) and mounted the receiver to match that configuaration.
Or maybe I'm just over analyzing it. . .
#36
My friend works at a Chrysler dealer and I have access to the Dealer connect site, and I haven't found anything about this on there. They have stuff about the vented seats and some other issues with numbers to call if you have problems, but nothing on this. I keep looking, mine does it also it is random like everyone else. Someday they will come up with the fix. I hope.
#37
me too
I have this problem at least once a day. If you use the vallet key the alarm goes off. I have the same problem with the inside lock button too. Seems like Dodge QA slipped a bit on this one. I love my Ram, but this bugs me sometimes.
Sometimes if i give the fob a little smack it seems to help, but I am sure it is just luck.
#40
I drive many highway miles for work. This problem seems worse when I have been on the road for a several hours non-stop. Today, every time I stopped at a rest stop the fob wouldn't work until after several tries. Eventually it works but IMHO it is a PITA!!!! There is no reason that they can't find the reason for this.
