Last edit by: IB Advertising
Browse all: Interior Guides
- Dodge Ram 2009-Present: How to Replace Smart Key Battery
Step by step intructions for the do-it-yourself repairs.
For those who's key fob stops working....
#181
If you can, try not carrying the fobs in your pocket all the time. It is possible the button is being depressed alot while you are not around your truck and the codes are getting out of sync. I carry mine in my backpack now and have not had a problem since. But I also got a new fob 6 to 8 months ago. I had an issue once with it. I am beginning to think that the buttons stick up on the fob and make it very easy to depress. Probably has a certain number of rolling codes and then gets out of sync with the receiver. After you push it a bunch of times trying to unlock the doors, they get back in sync. Whatever the case, mine has worked perfect since.
#183
I started to have an issue with mine only not unlocking right. I took the battery out and put a new one in the key and all is good again. I don't doubt that there are other issues with this setup just saying try a battery before throwing your hads up waiting on a Dodge fix.
#184
#185
#188
I have stumbled on a new bit of info here. I now question that it has anything to do with the FOB itself (a weak battery, bad connections, etc). This is because the FOB transmits a code. That code is either heard or not. Period. I now believe my truck always hears the request, it just forgets to respond. The reason I now am certain of this is because I have my locks set to unlock the driver's side on the first push, and all doors on the second. When it isn't responding and I am pushing it numerous times (never in rapid succession, always with a delay, so I know which push does what), I find that when it does finally respond (unlock + lights flash for the first time in the sequence), all four doors unlock. It would only do this if it had heard previous pushes and accepted them (in the module under the dash) but forgot to act on it) triggering the driver's door unlock and the flashing of the lights).
Just a new bit of info to add to the science here.
#189
Key Fob
I don't have a remote start, but it will shut down in the locked position once or twice a year. It always locks remotely---it just gets stuck in the lock mode. Once I manually unlock it and drive to that magic speed where it goes into autolock, everything is good to go for several months. Wierd stuff-----
