Stuck in 4th gear
Stuck in 4th gear
New to the website but long time reader.
My new crew cab has gotten stuck in 4th gear as soon as I put in drive 3 time now in the 3 weeks I have owned it. You can not get it to go up or down with the gear selector button on the shifter( column Shifter)....Putting it back in park or reverse and back to drive will not remove it from 4th gear. It will drive but only in 4th ....does not start out in 1st. The only thing that I can do is put in park and kill the engine . After restart it will go back to normal. I took it to the dealer and they kept it for 2 days driving all of the gas out of it only to tell me that they could not find anything wrong, codes etc....
I also have had no luck from the dealer on the vibrating gas pedal... they have no feeling in their feet...
8-08 build HEMI Crew with no MDS indicator on dash.....
Transmission Limp Home Mode
Chapter 5 Page 303
I wonder if this feature has anything to do with the trans getting stuck in gear?
"Transmission function is monitored for abnormal conditions. If a condition is detected that could result in transmission damage, the Transmission Limp Home Mode will be engaged. In this mode, the transmission will remain in the current gear until the vehicles is brought to a stop.
To reset the transmission, use the following procedure:
Of course, I have no idea what abnormal condition could cause this...
- Stop the vehicle
- Move the shift lever to the PARK position
- Turn OFF the engine and be sure to turn the key to the LOCK position
- Wait approximately 10 seconds, then restart the engine
- Move the shift lever to the desired gear range
Stuck in 4th gear
Dealer could not find any codes or recalls for this problem and wanted me to bring it to them while still stuck in 4th gear. Finially this past monday 8-10-09 it happened again and I drove it to the dealership in 4th. Kinda of scary getting on busy highway from a dead stop...not alot of acceleration.. They hooked up with the computer and were able to diagnose the problem... seems there was a new Flash to fix this. It seems to have totally changed they way it shifts through the gears ...for the better in my opinion.So far not any more problems with it.
The vibration in the gas pedal seems to be dependant on the road surface. If you are traveling on asphalt surface it disappears. The noisier chip rock surface will drive you crazy tickling the bottom of your foot. I tend to use the cruise control alot more just to take my foot off of the accelerator pedal.... I did try remounting the pedal bracket with some foam rubber under it ( sacrificed one of my beer coozies) but it did not help much if any. I plan on adding a stabilizer bracket to it next to try and stiffen it up.
That is exactly what mine did. Except the last time it happened, it stayed in 4th gear.
