Last edit by: IB Advertising
Browse all: Towing & Hauling Guides
- Dodge Ram 2009-Present: How to Install Trailer Brake Controller
Step by step intructions for the do-it-yourself repairs.
The complete story on the Trailer Brake Controller on 2010 Models.
#91
I just received the controller and bezel from mopar-wholesale.com, it cost about 115.00 shipped. It took about a 1/2 hour to install (with a beer break ) You need 2 screws to attach the controller to the bezel, I used the shortest 4MM fine screws I could find at the local hardware store. I tryed alot of different screws but the 4MM seem to "fit" the best. Now I just need to see if I can get it flashed at the dodge dealer.
#92
hOW TO TURN OFF evic MESSAGE TO SERVICE TRAILER BRAKE SYSTEM
I have a 2010 Dodge Ram 300DRW HD 4X4, I had an electric brake issue in my 7 blade connector, I found it and corrected it. Now how do I get the EVIC message "Service Trailer Brake control system" and of course I have the red trailer with the line thru it, its one of those factory intergrated control system and those lights stay on even with trailer off.
HELP!!!!!!!!!!
HELP!!!!!!!!!!
#93
Why the hell do they put a class IV hitch with wiring to the back for brakes and lights etc. Now if I install an after market controller I can just plug it in the big blue connector and well I don't have it in my EVIC **** I never look at it anyway. So the wiring somewhere on the frame shorts out....and my trailer brakes fail. Who is to blame? So really what is the difference, I would sign a waiver saying I would not hold them to blame if hooking up the OEM brake on my 09 failed I would not go after Chrysler as long as it was due to the hook up and not faulty controller or wiring after the controller.
#94
#95
Thanks for the info. I bought a controller form an Ebay seller. Then got the dash panel from my local dealer. $14.50. really cheap. I followed the direction and opend up my dash. I was only able to locate one connector taped to the harness.It was the 7 pin larger connector. Do I need to have both of them hooked up? My controller does not light up. Also, will it work If I do not have the dealer flash the ecu?
Thanks
Thanks
#96
