Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 4th Gen Ram Tech
Sign in using an external account
Register Forgot Password?
4th Gen Ram Tech 2009+ and up Rams: This section is for TECHNICAL discussions only, that involve the 2009 and up Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
The complete story on the Trailer Brake Controller on 2010 Models.
Thread Tools Search this Thread
  #81
Old 11-17-2010, 12:54 PM
autoengmike autoengmike is offline
Vehicle: 2010 Ram 1500 Laramie 4X4, Hemi, 3:92 gears
Finally out according to my dealer.
I started a new thread: http://dodgeforum.com/forum/4th-gen-...r-finally.html
Sorry, wrong information. Will update when finally available...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
  #82
Old 02-16-2011, 09:06 PM
llllll llllll is offline
my 2010 ram 3500 does that too. my trailer is older, who cares. the alarm bell sounds every five seconds saying the trailer brake is disconnected then connected. its ok on smooth roads but on bumpy roads it drives me nuts. i think it's a dodge software problem i don't care if the light comes on but the bell must be stopped
  #83
Old 02-16-2011, 09:18 PM
my truck does that too, every bumb the light and bell sounds trailer brake disconnected then connected. the bell makes me crazy.
  #84
Old 02-17-2011, 05:31 PM
mcclellandj mcclellandj is offline
Vehicle: 2009 Dodge Ram 1500 CC Hemi
Went with the P3, and installed it just like the video below.
http://www.youtube.com/watch?v=tcUAKOZ03xg
  #85
Old 02-26-2011, 08:14 PM
djf48 djf48 is offline
Will this also work for the 2011 2500 ST? Is the part number the same for the bezal? I would like to add the factory brake control and bezal to my truck but the dealer said it wouldn't work. Thanks
  #86
Old 03-16-2011, 01:13 PM
kingquadcab kingquadcab is offline
Vehicle: 2010 trx4 ram
Default integrated Trailer Brake Controller add on
I e-mailed CAGRIS Helpdesk Group [cagris@chrysler.com] today and this was the reply.'The Mopar kit number is 82212548 and it is currently available"
check into guys!
  #87
Old 03-16-2011, 08:33 PM
Oleksakjr Oleksakjr is offline
Vehicle: Dodge Ram 1500 Laramie 4x4
You dont need a "kit"
If you have the wiring in place, just buy the controller (part numbers is a few pages back) and the bezel and you're good to go. If you want it in the EVIC then get it flashed... pretty simple
I get a kick out of people waiting for this "kit" when you couldve just done it yourself a while ago...
  #88
Old 03-17-2011, 02:29 AM
72combo's Avatar
72combo 72combo is offline
Vehicle: 09 Ram 1500 HEMI 4x4, 72 Chevy C-10 350/350
Quote:
Originally Posted by drober30 View Post
I doubt Mopar would make it work for the 09 since it would be just one model year. That's to bad, I really like the factory integration.
Well it is obvious it was planned at some point since the same little pocket is on the 09 that is on all other years after that don't have the controller. The bezel and controller fit just like in the latter years. So they should have a plan for it, but really I am hearing it is going to be an obsolete controller in a few years because of the type of brakes....I was told this by several trailer companies....no they were not just trying to sell me a controller.
__________________
09 Brilliant Black Sport Hemi 4x4 CC,now has FUEL SAVER light. Mopar bed rug(awesome), Pace Edwards power locking gate, updated to RER,tinted windows,Husky Weather beaters, Craftec Tonneau, Mopar mudflaps,tailgate assist ram, Lockpick v3 with front and rear ccd cameras, Mopar running tubes,Cabin Filter Mod, DiabloSport catch can.
  #89
Old 03-17-2011, 06:35 AM
well, maybe this 'kit" has everything you went out and bought seperately. And maybe, it will tell what what build dates are effected. Some people don't have the time to sit around and try and figure out what has to be done to acomplish this installation. Seems like all the other posts go back and forth on what can be done or what can't be done. after awhile it gets confussing.
  #90
Old 03-17-2011, 09:18 AM
Its pretty simple man... instead of wasting your time for a kit it couldve been done a while ago. The kit will include everything I bought seperately for what looks to be a higher price too...
All you need to do is look for two connectors behind the cubby hole, if you have them buy the controller and bezel and your done. Connect it and screw it in... you dont even need the dealer to flash the truck it will work without the flash but it just wont display the brake info on your cluster. If you want that go to a deer and have them add the option code. You will need to do this same thing with the kit anyways
I dont see whats so hard about this, the kit does not include anything else. The only bigthing is if your truck has the plugs or not, so far it has nothing to do wih build dates but more of trim. Even then some slts have them while laramies dont. Thats the only issue...
Brake type obsolete?? I was told this eight years ago as well and electric brakes havent gone anywhere the guys full of himself. There are different types of brakes but they arent goin anywhere soon, youll be fine
  #91
Old 03-19-2011, 04:16 PM
I just received the controller and bezel from mopar-wholesale.com, it cost about 115.00 shipped. It took about a 1/2 hour to install (with a beer break ) You need 2 screws to attach the controller to the bezel, I used the shortest 4MM fine screws I could find at the local hardware store. I tryed alot of different screws but the 4MM seem to "fit" the best. Now I just need to see if I can get it flashed at the dodge dealer.
  #92
Old 08-18-2011, 05:58 PM
ROBERTHUDSON ROBERTHUDSON is offline
Default hOW TO TURN OFF evic MESSAGE TO SERVICE TRAILER BRAKE SYSTEM
I have a 2010 Dodge Ram 300DRW HD 4X4, I had an electric brake issue in my 7 blade connector, I found it and corrected it. Now how do I get the EVIC message "Service Trailer Brake control system" and of course I have the red trailer with the line thru it, its one of those factory intergrated control system and those lights stay on even with trailer off.
HELP!!!!!!!!!!
  #93
Old 08-18-2011, 11:49 PM
72combo's Avatar
Why the hell do they put a class IV hitch with wiring to the back for brakes and lights etc. Now if I install an after market controller I can just plug it in the big blue connector and well I don't have it in my EVIC **** I never look at it anyway. So the wiring somewhere on the frame shorts out....and my trailer brakes fail. Who is to blame? So really what is the difference, I would sign a waiver saying I would not hold them to blame if hooking up the OEM brake on my 09 failed I would not go after Chrysler as long as it was due to the hook up and not faulty controller or wiring after the controller.
__________________
  #94
Old 04-03-2013, 10:49 AM
jhardin80 jhardin80 is offline
Vehicle: 2010 Ram 1500 Quad cab SLT 5.7L HEMI
I have a 2010 with the one connector and I got my controller and bezel in yesterday and had it installed in about an hour. Everything is working like it should! I just need to find a dealer to flash my system for free!
Thanks for all the great info on here!
  #95
Old 04-15-2013, 11:59 AM
eyera3 eyera3 is offline
Thanks for the info. I bought a controller form an Ebay seller. Then got the dash panel from my local dealer. $14.50. really cheap. I followed the direction and opend up my dash. I was only able to locate one connector taped to the harness.It was the 7 pin larger connector. Do I need to have both of them hooked up? My controller does not light up. Also, will it work If I do not have the dealer flash the ecu?
Thanks
  #96
Old 04-16-2013, 12:14 AM
wobly wobly is offline
Vehicle: 2010 Dodge RAM 1500 4x4 SLT
Do you have the factory controller or an aftermarket one? If it is factory, it requires both plugs to be hooked up. But, if you only have one plug, you can wire in the second one. I think the instructions are a couple pages back.
I had one plug and bought a Prodigy3. Love it!
__________________
2010 Ram 1500, tinted the windows, added the remote start, added towing mirrors. Work in progress!
  #97
Old 04-16-2013, 11:13 AM
It's an OEM controller. I'll look for the directions for adding the second pig tail. The truck does have the oem tow package.
Thanks
Tags
2010 brake controller, evic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Contact Details & Emails
