4wd light flashing - DodgeForum.com
4th Gen Ram Tech 2009+ and up Rams: This section is for TECHNICAL discussions only, that involve the 2009 and up Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Old 08-05-2015, 01:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Four Wheel Drive Guides
Print Wikipost
4wd light flashing
Old 02-03-2011, 11:10 PM
KKG
KKG is offline
Default 4wd light flashing
My 4wd light flashes and won't stay constant lit. Seems as though the 4wd is engaged. Anybody know anything about this? It is a 2011 Ram. Thanks
Old 02-04-2011, 07:16 AM
JohnKoz
JohnKoz is offline
Same here, thought it was normal, it's not?
-John
Old 02-04-2011, 07:42 AM
RAMULAK's Avatar
RAMULAK
RAMULAK is offline
Mine only flashes when it is going into or out of 4x4. Stays on once it is in, or goes out when it is out. 2009 Sport.
desired position. Refer to “Shifting Procedure” for specific
shifting instructions. The 4WD LOCK and 4WD
LOW positions are designed for loose, slippery road
surfaces only. Driving in the 4WD LOCK and 4WD LOW
positions on dry hard surfaced roads may cause increased
tire wear and damage to the driveline components.
NOTE: The transfer case NEUTRAL position is selected
by pressing the recessed button located on the lower left
hand corner of the 4WD Control Switch. The transfer case
NEUTRAL position is to be used for recreational towing
only. Refer to “Recreational Towing” in this section.
Transfer Case Position Indicator Lights
The Transfer Case Position Indicator Lights (4WD and
4LOW) are located in the instrument cluster and indicate
the current and desired transfer case selection. When you
select a different transfer case position, the indicator
lights will do the following:
If all shift conditions are met:
1. The current position indicator light will turn OFF.
2. The selected position indicator light will flash until the
transfer case completes the shift.
3. When the shift is complete, the indicator light for the
selected position will stop flashing and remain ON.
If one or more shift conditions are not met:
1. The indicator light for the current position will remain
ON.
2. The newly selected position indicator light will continue
to flash.
3. The transfer case will not shift.
NOTE: Before retrying a selection, make certain that all
the necessary requirements for selecting a new transfer
case position have been met. To retry the selection, turn
Old 02-04-2011, 11:09 AM
KKG
KKG is offline
Hmm...yeah my 2010 stayed constantly lit. Now I come home with my new diesel last night put it in 4wheel and it did that. Was hoping something had changed.........uggghh. thanks
Old 02-04-2011, 01:54 PM
depunz
depunz is offline
Default Solution.
Mine did this a while ago. Dealer said to put it in 4low, then back in 2 wheel, then back in 4 wheel hi and that should take care of it. Worked for mine and another guys here on the forum.
Old 02-04-2011, 02:03 PM
OhioChuck
OhioChuck is offline
It helps, too, to stop, put the trans in reverse, go a few feet, stop, then back to drive.
Chuck
Old 02-04-2011, 03:47 PM
10hemi
10hemi is offline
Its prob stuck trying to get out of 4L mine does that if I dont get it all the way out
Old 02-04-2011, 07:29 PM
Gary C.
Gary C. is offline
Nothing like a good old T-Case shifter to jam into and out of gear... sometimes a pain in the ***, but you always knew if you were in 4WD or not (assuming you remembered to lock the hubs)...
Old 02-04-2011, 08:15 PM
KKG
KKG is offline
Yeah and I always thought manual t case were laughable when dealers ordered them these days, boy was I wrong. Yeah I'll have to try putting it in 4LO haven't done that yet. But did try stopping and going in reverse and all of that. 4 wheel works just fine. Talked to a dealer earlier today he said there has been some problems like that, some wiring and sensor problems.
Old 02-05-2011, 08:09 AM
TDTIPMO
TDTIPMO is offline
yeah mine used to do that. I had to take it in and the dealer just reset the 4 wheel drive module? Where ever that is. The first stealer said they had to order a new one, but that's a whole other story. I ended up taking it somewhere else and I got it back the same day. My problem was when I had it in 4x4 the light just flashed. It wasn't engaging. So I don't know if it's the exact same problem, but it seems related. Good luck.
Related Topics
Thread
Forum
Replies
Last Post
m0rb02
Dodge Caravan
2
04-19-2016 04:06 PM
keouchao
Dodge Caravan
1
07-18-2015 11:35 PM
BrandonBuc'em
2nd Gen Ram Tech
4
07-15-2015 02:02 PM
kenb1023
2nd Gen Ram Tech
2
07-06-2015 01:44 PM
barrd70
2nd Gen Dakota
0
07-05-2015 02:23 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
