Last edit by: IB Advertising
Browse all: Engine Problem Guides
- Dodge Ram 2009-Present: Engine Noise Diagnostic Guide
Guide to diagnose trouble and recommended solutions.
Ticking sound when coasting?
Fine.. then press the DOWN button on the column shifter and put it in 6th gear.. then coast. Does the noise go away? This also turns the MDS off, but doesn't send it to 4th gear.
The following users liked this post:
Pvt Pyle (03-03-2022)
UPDATE: Ticking sound at coast down
Since my last post about this problem I have installed new factory front brake pads and rotors, and this has apparently changed the symptoms. I changed the front brakes because the rotors were exhibiting severe hard spot symptoms.
First, although I cannot adequately describe the difference, the ticking noise has changed and no longer seems as metallic in nature.
Second. The noise completely disappears when applying the brakes, every time. So by doing something I've changed something.
I don't know why this never dawned on me before, but the connection to the brakes made me realize that the sound appears to be synchronous with the revolution speed of the wheels.
I found that one slider pin on each front caliber mounting bracket (what Chrysler calls the adaptor) was rusted frozen and the rotors were highly glazed. I actually had quite a bit of pad left, which surprised me at 83,000 miles.
Although the rear pads are not even half worn, the condition of the rear rotors appear to be the same as the old front rotors: highly glazed. So I'm thinking of tearing the rear brakes apart and probably replacing at least the rotors.
As an aside, I could not believe how much better this truck stops with new pads and rotors.
I'll keep everyone posted on what I find.
Best regards,
Dusty
2010 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 545RFE, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 83,000 miles.
Best regards,
Dusty
Putting the transmission in the TRS mode and driving in 5th gear, no sound at coast down.
Selecting Tow/Haul mode, no sound at coast down.
Putting the transmission into neutral, the sound disappears.
In normal driving mode the sound disappears at around 1200 RPM regardless of road speed.
The common factor with all four is the MDS. (MDS is off in neutral, Tow/Haul mode, TRS mode, and at or just above idle. I specifically watched the ECO indicator and sure enough when the ECO indicator goes off on coast down, the noise disappears.
Oddly, I've also noticed lately that the engine idle is somewhat rough at 650 RPM. Normally it idles at 500 RPM in gear after warm-up, but lately it seems to idle to 500 RPM after a stop and then raise to 650 RPM after a few seconds. This is roughly the same idle speed you would see when you switch on the air conditioning. This is not consistent and I'm not sure this is related.
Next stop, my local Dodge dealer.
Regards,
Dusty
Ticking Noise in ECO Mode: Problem Resolved(?)
As previously posted, the ticking noise from my 2010 Ram 5.7 appears to have been resolved. Before I share what fixed it, I'd like to poll those of you that have had this problem with the following questions:
1. Please advise on any repairs to the engine that may have been performed within the last year.
2. What type of motor oil are you using (i.e.: manufacturer, viscosity, blend name).
Thanks,
Dusty
2010 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 545RFE, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 84,000 miles.
Thanks,
Dusty
Ticking Noise when coasting under 40mph with MDS on
Thanks,
Dusty
Thanks,
Dusty
I have the same noise when coasting and it goes away when MDS is off. I think its just the sound of the lifters or pistons not firing. It has never stalled or caused any problem. I am not a fan of the MDS but it does help on Gas. Some claim that even with their MDS off mileage does not change. (Don't Believe it!) Although reliable for the most part these Hemi's have their quirks.
