Last edit by: IB Advertising
Browse all: General Overview
- Dodge Ram 2009-present: Recalls and Technical Service Bulletins
Important information to help you understand your Ram.
N08 Rear End Recall
#91
Huh? Never heard of a crush sleeve that you back off of after crushing. You torque to the crush spec and leave it alone.
#92
#93
2010 Ram with 45,000 miles and I brought it to the dealer for the N08 recall and some whining....I guess both me and the truck.
I now have 55,000 miles on the truck and the diff has been "rebuilt" three times.
The last time (last week) the only thing left original from the original diff....was the axles.
And guess what?
It is starting to whine again at speed and I get this low drone when starting from a stop for about 2 seconds.
Ho Hum.
And guess what?
Ho Hum.
#94
And guess what?
Ho Hum.
And guess what?
Ho Hum.
I'm sorry to hear the whine is still present. Please feel free to PM me your Vehicle Identification # (VIN) and the dealer you're working with.
Thanks,
#95
I'll tap you in the future if the problem persists and just before warranty runs out in February.
Thanks......
#96
I'm pleased to hear your dealer is taking good care of you. Your dealer has professionally trained technicians and the necessary resources available to pinpoint the root cause.
I'm happy to help out when I can.
#97
More frustration....
I had the N08 recall done--dealer installed the new retainer and said everything was fine. I drove out of town for 3 hours and the rear end started to sound like it was going to drop out. It was fine prior to the retainer being added. Got it back to the dealer, and they now said it needed an overhaul...pinion bearings, etc. So they overhauled it. Now, 50,000 km later (30,000 miles) there is a loud whine from the differential. I had a bit of an issue with my transmission and had a very good local transmission shop test drive the truck. Transmission issue was minor, but the owner of the shop said "the pinion bearings are gone in your differential." Coincidentally, the owner of the shop has a 2010 Ram and the same thing happened to him at the same dealer. Took his truck in for the recall (installed retainer) and now the rear end is whining. He's taking it back, and I guess I'll be battling with the dealer myself next week. In almost 40 years of driving this is the first vehicle I've ever had differential problems with...never mind repeated issues.
#98
#99
#100
So....diff number 3 has gone to schitt. Didn't last that long, either.
I had a sit down with the Chrysler service manager and a test drive.
He has given me assurances that I will be covered after my 5 year warranty is up due to the long and documented history.
Warranty runs out Feb 28 and I have the trucked scheduled for diff number 4 Feb. 17. I figured I'd get the trani and transfer case fluid changed at the same time.....give them a chance to have a look before the warranty was up.
I'm having minor surgery and will be out of commission for 2 weeks so they will keep the truck for at least a week to fix and test.
Hopefully this will be the LAST time for this problem.
This will be 6 diffs on 2 trucks over the last 3 years!
