Wheel bearing problems?
Old 02-13-2011, 02:50 PM
laramie09's Avatar
laramie09
laramie09 is offline
Default Wheel bearing problems?
Anybody have any issues with their front wheel bearings? I have a 2009 Ram 1500 Laramie. I had an ABS code for the left front sensor and a grinding noise in the front end that got louder when turning. Turns out that the bearing was bad and no longer under warranty because the truck has 48k miles. I replaced the hub, bearing and abs sensor, which fixed the problem with the abs, however the noise is still there. Dropped the truck off at the dealer and they tell me that both front wheel bearings are bad, including the one that is only a week old. I've opened a case # with Chrysler and am waiting to here back from them. Just wondering if anyone else has had any similar issues.
Old 02-13-2011, 07:01 PM
Gary C.'s Avatar
Gary C.
Gary C. is offline
Sorry to hear about your problems. My '07 had the from wheel bearings go bad right around 50k, so it sounds like your problem isn't unique. Unfortunately, not cheap.
Old 02-14-2011, 07:10 AM
TDTIPMO's Avatar
TDTIPMO
TDTIPMO is offline
Oh damn. I find it a little fishy that you're week old wheel bearing is bad, sounds like a classic case of a stealership to me. Hopefully you get some good news about the case.
Old 02-14-2011, 08:38 AM
05Dakotaho's Avatar
05Dakotaho
05Dakotaho is offline
D'ya think the neg. 12mm offset on those aftermarket wheels might have something to do with the bearing failure?
Old 02-14-2011, 12:46 PM
laramie09's Avatar
laramie09
Wheels, tires and suspension are all original. Best part is they diagnosed it as wheel bearings on both sides just by having 3 different people joyride my truck around. When I told them I don't think its the bearings and asked if they put it on a lift to check it they said no. Dodge service is a f*ckin joke!
Old 02-14-2011, 12:52 PM
05Dakotaho's Avatar
05Dakotaho
Oops, read the wrong poster's signature line.
Is your Ram a 4wd?
Old 02-14-2011, 01:02 PM
laramie09's Avatar
laramie09
Cool
Is your Ram a 4wd?
Yes, it is 4wd
Old 02-14-2011, 01:05 PM
05Dakotaho's Avatar
05Dakotaho
Have you had the CV joints checked?
Old 02-14-2011, 01:14 PM
laramie09's Avatar
laramie09
That's what I'm thinking it is. That would be covered under warranty, maybe that's why they haven't checked them. Would a cv joint make a grinding noise in a 30 mph turn? I haven't heard any clicking noises the you would normally here from a bad cv joint.
Old 02-14-2011, 01:18 PM
05Dakotaho's Avatar
05Dakotaho
I don't know. I was only guessing. Hopefully someone with more 4wd experience on this forum will chime in.
Quick Reply: Wheel bearing problems?
