Motor stuck - DodgeForum.com
4th Gen Ram Tech 2009+ and up Rams: This section is for TECHNICAL discussions only, that involve the 2009 and up Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Motor stuck
Old 06-07-2014, 10:34 AM
brunswickmariner's Avatar
brunswickmariner
brunswickmariner is offline
Angry Motor stuck
Has anyone had or heard of issues with these 5.7s, mine has been working great up to last night, pulling on a old tree and engine shut down, would not turn over pulled starter and tried turning engine with power bar on harmonic balancer, will not budge.
Old 06-07-2014, 10:40 AM
plumcrazy73's Avatar
plumcrazy73
plumcrazy73 is offline
is there oil in it
Old 06-07-2014, 11:16 AM
NoMoreGMsForMe
NoMoreGMsForMe is offline
Possibly a bent crankshaft.
Old 06-07-2014, 12:55 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
I wonder if you did something to your torque converter/trans pump that is locking it up???
jack the back wheels up and put truck in neutral. Try to turn tires. If they spin, try to start engine while in neutral but do NOT leave it running.
If still no luck, then you will have to drop the oil pan and check out the lower half of the engine for bearing/rod damage.
btw. Whenever you are pulling out vehicles or stumps, you should be in reverse and use front mounted tow hooks. You never want to yank a vehicle out from the rear. I see it all the time and it's not recommended.
Old 06-07-2014, 02:26 PM
brunswickmariner
Default Motor Stuck
Ok, screwed with the transfer selector and got engine running and have no gears fwd or rev. Check trans fluid and level is high but was ok before. Torque converter maybe ?
Old 06-07-2014, 02:37 PM
Pedro Dog
Pedro Dog is offline
Sounds like the TC is good and probably the tranny also, check the rear differential. Crawl underneath and check the trasfer case for cracks. Also look at the rear differential, two ways to do it. One, take the cover off and look at it, but then you will have to refill it, another way is to take the rear drive shaft off and then put the trasfer case into 4wd and see if the truck moves. Also, with the drive shaft off and the back tires off the ground, try to spin them by hand.
Old 06-07-2014, 10:29 PM
RSDodgelover
RSDodgelover is offline
Quote:
I know nothing about the transmissions but have been told all my life to never pull hard in reverse as the ring gears are not designed for it. I've seen a couple of differentials exploded that way. JMO
Old 06-08-2014, 09:35 AM
Duso02
Duso02 is offline
Quote:
x2....Every recovery class I've taken always said to pull from the rear when possible. Everything in the drivetrain is stronger when going forward. Hell, our military 5-ton truck xfer cases were built so you couldn't back up in low. If you did, they exploded, and I actually witnessed that one. That's a mess.
Old 06-13-2014, 02:14 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Maybe the differential isn't as strong, but the reverse mech inside most transmissions is stronger than any forward gear!
OP's problems are transmission based, not axle/ring/pinion based which is why I mentioned it. Axles breaking will not cause the engine to shut down. A frozen torque converter will!
I'd much rather replace a broken ring gear than a whole transmission.
I'll stick with what I already said. Either his TC or pump is shot. Anytime you have to rev the motor while in gear means the torque converter is slipping. Slipping creates excessive heat. Roughly 20*F rise every second your slipping it. So, do this for a solid minute and your fluid temps are over a thousand degree farenheit. This is enough to seize the pump.
Old 06-13-2014, 03:06 PM
Pedro Dog
I wish these guys that come into the forum asking for help would come back and post the resolution, it's like they are in it only for themselves.
Seems to me that if he got the engine to start and run with messing with the transfer case (probably put it in neutral) that this would rule out the TC.
Related Topics
Thread
Forum
Replies
Last Post
yhike
6
08-22-2015 11:55 AM
Robertcalahan23
Dodge Caravan
4
08-19-2015 05:40 PM
cutthroatxxx
2nd Gen Ram Tech
3
08-07-2015 11:56 AM
salrt
3rd Gen Durango
26
07-23-2015 10:34 AM
janicedauw
Dodge Caravan
1
07-04-2015 08:12 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
