Overhead console green light led ashtray cup holder
Hello all. My overhead consol light, the green one in front of the power rear window button, has been flickering on and off. Now it doesn't seem to come on at all. If you search for the replacement no one has a part number. I have looked high and low and talk to the dealer. Many people are saying it is called an ashtray light or cup holder light claiming the bulb number is a 37. This is not true. I had the dealer order me the 37 bulb and it isn't correct. This is a filament bulb. The dealer now told me the only way to replace it is to order the whole overhead consol. That is completely rediculous. Part number 1pq09bd1aa.
I'm not paying $40-$50 for that. Does ANYONE know of a direct replacement for this led light?
See attached picture for what this thing looks like. I know I can't be the only one with this problem. Thanks.
I had mine out tof my 2010 tracing a noise issue. If I remember correctly, the body of what I see in the picture is just the prizimatic projector. Isn't the LED just pressed into that body? If it is, and your small electrical component talents are high, maybe the LED could be replaced separately.
Maybe this helps? (Maybe not.)
Best regards,
Dusty
2014 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 004500 miles.
Best regards,
Dusty
Any news on this? I was thinking about trying to find a brighter light. I didn't even notice that there was a light there until the other day I read something on a forum somewhere about there being a light. I was trying to find out what that other round lens looking deal is on the overhead console.
I bought this square led from super bright LEDs. And just put a dab of super glue on the face of the led. Where it sits is acctually square. It is almost a perfect fit and it is brighter. I just jammed the wires in the existing socket because I didn't want to cut the factory "harness". But it would probably be better to use a butt connector or solder them.
Little Dot SMD LED Accent Light
LD1-G
https://www.superbrightleds.com/moreinfo/led-wired-bolts/little-dot-smd-led-accent-light/639/
LD1-G
I don't have a picture. I haven't acctually drove in the night since I put it in. But I can tell it is certainly brighter, even in daylight if I put my hand close to it.
It is only $2.00, and comes in several different colors. I just ligjts up the cup holder and floor shifter area. I had to replace it because it was flickering and was a huge distraction while driving at night.
Trending Topics
Are you sure it is a bad LED? Have you checked for power at the incoming wires/plug? Perhaps it is a problem with the wiring harness or somewhere before that. LEDs have really long life and unless they get physically damaged (like corrosion in the puddle lights) I think it would be odd for one to 'burn out'. Especially not in a "flickers for a while then doesn't come on" mode. Filament bulbs flicker as the filament erodes and breaks. LEDs are electronic. I'm no expert but I wouldn't think that's how they would go out.
Rob
Rob
