Laramie heated and cooled seats in a base model Ram
Hello i am new to the forums and i am trying to install 2014 dodge ram Laramie heated and cooled seats in a 2012 dodge ram 2500. the seats in the truck are non power non heated. i know i need the switch and the ecm flashed to make them work. the wiring harness for the switch is just behind the radio bezel. the seating module is mounted on the seat and the part number is Continental P68058083AI and the other one says MSM P05026618AE
can you point me to the correct wiring harness i would need to purchase the correct wires i need to splice[if needed] or if i need to purchase any modules because they are incompatible with a wiring harness with wiring harnesses?
any pictures of 2012 and 2014 ram seat module wiring harnesses are definitely appreciated
if you're asking yes the juice is worth the squeeze
Thank You,
Kevin
Thank You,
Kevin
ok i found the part numbers for the harnesses for under the seats and the modules are under the seats. i pulled back my dashboard to see if the wiring for the heated switch was there and it wasnt. can that part of the harness be purchased separately?
i really need pictures of a 2012 ram with heated seats and if possible pictures of how the seats connect to the dashboard and how the switch connects to the dash [eg where the harness comes from]
have you found the dashboard harness you where talking about, I doing same conversion
