4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
both lights came on the morning of a trip and when I got to town for gas they stayed on. I went to dealer there and they put it on computer and did an upload and said that should do it. unplugged it and started up and lights still on. He did this about 4 times and could not figure out the problem. My 4w/d and cruise control will not work also.
Well, you still have an ABS fault that isn't fixed. Cruise will not work if an active code is present, neither will 4wd. Flashed same module 4 times?? Dealer sounds like a window licker.
only active code was for my wheel pressure sensor which works on and off but everything else showed inactive. taking it in tomorrow to dealer here finally to see if they can figure it out. Hope it wont break the bank.
thanks for the help, took it in and they wiped the memory and ran it again and it came up a dynamic sensor was bad. also had them replace the speed sensor since it was still under warranty. still 600 bucks to replace the dynamic sensor
Has anyone checked the brake light switch over the brake pedal. I had one go bad and abs and 4WD light stayed on. Also kept my brake lights on from time to time. That would keep your cruise control from working as well.
