DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 4th Gen Ram
Thread Tools Search this Thread
Old 04-12-2008, 10:43 PM
94rt10ohio's Avatar
94rt10ohio 94rt10ohio is offline
Site Administrator
Dodge Forum Administrator
2004 Dodge Ram SRT-10
My Garage
Vehicle: 94 Viper RT/10
Send a message via AIM to 94rt10ohio
Default Ram 4th Gen Do It Yourself Information
Click for Ram 4th Gen DIY.
DIY's are supplied by you, our members! If you would like to add a DIYPM the DIY to HammerZ71or94rt10ohio
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
04 Ram SRT-10<--Click For Sale PM for details
09 Ram 4x4<--Click
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-04-2009, 10:28 AM
blue2050 blue2050 is offline
2009 Dodge Ram 1500
My Garage
XDI Intake increase gas milage and is available. Louder intake noise when you get on it.
Only place I know to get the XDI for the 2009 hemi is
http://www.totalappearance.com/
You haveto call, talk to Tim. XDI does not sell to the public
...and if you write XDI from Florida XDI tells total apperance to call you.
http://dodgeforum.com/forum/4th-gen-...cessories.html
Old 01-13-2009, 10:49 AM
Dr. Bill Dr. Bill is offline
2009 Dodge Ram 1500
I am a DIY guy. I do all my own maint. unless it has to be done at the dealer because of warranty issues. I have not had to do anything to my 09 yet, but I will tell you that it will not be as easy as the previous generation. I have noticed that the power steering pump has no dipstick to check its level. The coolant recovery tank is black so you can not see your water level. There is some weird stuff on this truck. I have no idea what the engineers were thinking or what else we will find during the next few months. I still can't get over the recovery tank, just plain nuts.
Old 01-15-2009, 12:42 AM
savage_46 savage_46 is offline
Vehicle: 09 ram
Quote:
theres no p/s dipstick cause the reservoirs are now "clear-ish" and you can see the level through the outside. also has the min/max or cold/hot lines embossed in. the coolant recovery is no different than the old dakota/durangos. although i dont remember if they have dipsticks, pretty sure they do.
Old 01-15-2009, 10:27 AM
2009 Dodge Ram 1500
Quote:
I will look at the PS reservoir again. I did notice that it was kinda white, but I did not notice any markings like the brake reservoir. I hope it does, now what about that coolant tank? I guess they wanted it black because it sits right in the front of the grille opening.
Old 01-20-2009, 11:02 PM
Vehicle: 09 ram
i made sure to pay attention the other day when i had an 09 in. there is a coolant dipstick for the reservoir. cant really remember about markings on the p/s. the p/s work ive done with the new style reservoir, ive filled to the seam about 2/3 they way up--no noise or air bubbles, or low fluid complaints.
Old 01-21-2009, 12:06 PM
2009 Dodge Ram 1500
Savage,
You are right, the ps tank does have markings. The are much harder to read than the one for the master cylinder.
The dipstick for the coolant is a poor design. It has no markings, just some holes. Of course, the water is too thin to stick to the stick or holes, so I guess just look in the tank and see if there is any water when it is cold and you will be fine. It would have been nice if a scale with a clear window was on the back side (eng side) so that you could see the coolant level. It would have made the tank cost a few pennys more, but would have been worth it.
Old 01-24-2009, 08:02 PM
2009 Dodge Ram 1500
Warning! Before you drain the oil on your first oil change, the nuts at Mopar have changed to a larger thread on the filter. Mopar has always used the 05281090 (m0-090) on everything, not on the 5.7 2009. So you can get rid of your Purolator L14670 and your Fram ph16s.
I had to borrow my dad's truck and go get the correct filter. You can use several different filters, here a few:
Wix 51372 or 57899
Purolator L24651
Bosch 3410 or 72212
Hastings Lf110 or Lf 612
Baldwin B329
Donaldson P550965
AC PF26 or PF1250
Motorcraft FL-820S
I hope this helps all of you DIY guys.
Old 03-08-2009, 07:28 AM
kxwhite kxwhite is online now
2009 Dodge Ram 1500
Vehicle: 09 Ram 1500 Sport
and after you have changed your oil filter to clear the "oil needs changed" reminder:
turn the key all the way to the on position (do not turn it all the way to crank the motor over)
turn the key back to off postion
turn the key back to the on position.
hammer down on the gas pedal 3 times
turn the key to the off position
when you start up the truck the reminder will be cleared.
Old 03-08-2009, 07:36 PM
WVU Fan WVU Fan is offline
Vehicle: 09 Dodge Ram SLT Crew Cab 4x4
It's not necessary to turn the key on, then off, then on again. Just turn it to the on position, fully depress the gas pedal 3 times within 10 seconds and then turn the key off.
__________________
Current Ride: 2009 Dodge Ram 1500 SLT Big Horn Crew Cab 4x4.
Tags
05281090, 57, 57899, air, bubble, coolant, dodge, filter, fram, hemi, mopar, motorcraft, oil, ram, wix
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
