DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 4th Gen Ram
Thread Tools Search this Thread
Old 06-03-2009, 08:16 PM
Zbach7's Avatar
Zbach7 Zbach7 is offline
Default Anyone have Bakflip HD?
I think they sent me the G2 instead of the HD. I only got 6 mounting clamps, pivoting arm is zinc coated and doesent seem that rigid.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-03-2009, 09:15 PM
oldjeep's Avatar
oldjeep oldjeep is offline
Vehicle: 2009 2wd SLT Crew Cab
I ordered one yesterday. Should be pretty easy to tell, the HD is aluminum on the outside of the panels and the G2 is some sort of plastic. Also the G2 is supposed to be 1/2" thick and the HD is 5/8"
__________________
09 Ram 1500 2WD SLT Crew Cab
http://www.oldjeep.com
Thinking of buying a BakFlip HD - read this:
http://dodgeforum.com/forum/4th-gen-...not-so-hd.html
crod crod is offline
if its aluminum its the HD. if its plastic its the g2. you should be able to tell the difference quite easily. i will have my hd sometime next week.
Old 06-03-2009, 09:17 PM
oldjeep's Avatar
Judging by your description I'd say you got a G2. Where did you buy it from?
BAKFlip HD has the following refinements:
  • Panels on HD are 5/8" thick vs 1/2" thick for the G2
  • The BAKFlip HD's textured flat aluminum surfaces on all panels have two coats of epoxy primer that is baked on at 460 degrees. This entire expoxy primer coating process is completed twice (first coat applied, baked on and cooled, and then the process is repeated). Once the two coats of primer has set, an extraordinarily tough and scratch-resistant polyester based coating is used as the final finishing coat (which gives the look of a tough, baked on enamel, but is much higher quality). This coating process ensures that the covers is both scratch and UV resistant.
  • The 2 stage enamel process makes for a final finishing coat that is more of a factory look
  • The BAKFlip HD's core is 25% more dense than the BAKFlip G2. As a result, the BAKFlip HD handles approximately 25% more distributed weight when compared to the G2. The HD is much more rigid then the G2.
  • Quality and Rigidity Standards Endorsed by OEM - The BAKFlip HD® is an Original Equipment Part for one of the Big 3 Automakers
  • 2 year warranty for the BAKFlip HD vs. 1 year warranty for the BAKFlip G2.
  • Powder coated pivoting arms - (G2 has zinc plated)
  • Integrated tie down points underneath and on top of the cover (“D” Rings placed at strategic points under the cover).
  • Extra Set of Clamps (8 clamps) provided for added rigidity (4 on each side). The G2 uses a total of 6 clamps.
  • The BAKFlip HD has a higher quality finished look when compared to the BAKFlip G2 because of the 2 stage epoxy primer on the HD.
  • For an extra $250...you get the absolute best product for your truck with the BAKFlip HD
__________________
Old 06-03-2009, 10:39 PM
Zbach7's Avatar
ebay Store champion is the name of the seller. Cant really tell if its aluminum or just a hard plastic with enamel on it.
Old 06-03-2009, 11:23 PM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork BubbaRadioNetwork is offline
Vehicle: 2009 Ram TRX4 Hemi Crew
Does it have a part number on it anywhere?
__________________
'09 Ram 1500 Hemi TRX4 Crew Inferno Red
Bucket seats, sunroof, TorzaTop, hood deflector, Mufflex 14"
Old 06-04-2009, 12:09 AM
ABDodge ABDodge is offline
Default Bakflip HD or G2?
This is a good question. I ordered an "HD" and picked it up. When I got it home I thought "This is a G2". The part number was for a G2 (26203, should be 35203), there were only 6 clamps, the instructions were for a G2, etc. Then I wasn't sure about the material as when I tapped it to see if it was aluminum it was hard to tell because of coating on it, it sounded somewhat metallic but also like plastic with a coating. I called the shop and discussed it with them, they assured me it was an HD, their numbers in their computer weren't changed when the HDs started coming. They said that they have an agreement with the manufacturer to get only HDs but they come in a G2 box. It all leads to unnecessary confusion. At this point I am still not 100% sure that I have the HD. It would sure be nice to know that I got what I paid for with the extra $250 I spent.
The main issue is with the manufacturer. They are producing, marketing and selling a new product but their online support (pictures, instructions etc) for the HD is weak. I want to see pictures of a HD and a G2 so I can compare. I also want instructions for a HD not for a G2 etc. It is frustrating paying considerable $ for something and having a lot of unnecessary questions, uncertainty and hassle because they feel that "Coming Soon" is an adequate response when looking for info from them.
Having said that I am happy with the "HD?" that I have so far. It is still brand new, no water test etc yet but looks good. It is just too bad that you have to open the cover every time you want to close the tailgate.
Old 06-04-2009, 07:18 AM
oldjeep's Avatar
Have you measured the thickness? And does your cover have the d-rings under the cover?
Now you got me concerned, I hope the correct cover shows up when they ship mine. I bought mine from JCWhitney, but their part number is ZX539173
__________________
Old 06-04-2009, 01:29 PM
U got me worried now I. Thought I'd would be easy to tell the difference......
Old 06-05-2009, 05:06 AM
Default HD or G2?
[quote=oldjeep;1690746]Have you measured the thickness? And does your cover have the d-rings under the cover?
Measuring the thickness is not a very exact science, especially since you are trying to distinguish a difference of 1/8 inch. You can't get directly to the panel and it is not smooth, there are high spots and low spots, part of the textured coating. Yes, mine has D rings, it also has the support arms, arm stay locks, elevator bolts etc as shown in http://www.bakfliptonneaucover.com/installation
which is the description on how to install a G2. That is the issue with the lack of info on the HD, you can't compare and say "yes, that's what I have". Especially when the box shows up with a G2 part number.
Tags
2009, bakflip, champion, diamondback, dodge, ebay, g2, hd, measurements, ram, shut, store, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
