Good kill man, ive been looking for an 09 rcsb hemi to run. I kinda had the same result against the 09 4 door rams. I get them by at least 2- 3 lengths by 60-65ish. Took forever to line up with one, there are so few newer rams out here in so cal.
Sounds about right though, your probably a low 14 second truck and the double cab tundra is a mid to high 14 second truck.
no shame in losing to vettes or mercedes. It sucks getting your doors blown off by a lightning from a 30 mph roll. Im sure he wasnt stock, but still stings a little.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
2008 5.7 Tundra RCSB- Sport Appearance Package, Volant CAI, Magnaflow Dual Exhaust, Custom H pipe, Unichip Custom Tune, Toyota 20" Carved Wheels, McGaughy's 2/4 drop kit, Blacked out Tail lights.
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I agree the truck pulls hard at speed but it still isn't 390hp, probably 50+ hp shy of it. Of course thats expected, the truck has a lifetime powertrain warranty so it will certainly be "detuned" significantly. I'm not getting a programmer for the fear of getting my warranty voided, I can live with the power it has.
Hes added so many really cool parts to it i think its in its own catagory now
Thank you Sir, it has been a work in progress and a labor of love.
Quote:
Originally Posted by lross78550
Blown, how hard is it to tune one and get the mixture right after adding a blower with that much boost?
It was more difficult for Hemifever than I because he wrote my fuel maps. With the wideband O2 and boost gauge, I would give him readouts at every RPM range all the way to WOT. The only fuel maps I had to work were for the alcohol injection program. Running a cylinder lean is always a concern, the R1 Racing Meth I run helps with that also. It drops my A/F to a really rich 10.9-11.2 or so.
72Combo, the 355 isnt limited slip is it? If not i would change to a 392 for that alone, Our truck needs a 355 gear like it needs a drag chute. Your never going to drive fast enough to get the use of a 355 gear so why not use that power getting off the line.
JMO Lee
That has been a great debate, power off the line or up high. I went with 4.10 gears knowing with the blower the 3.55s would be better up high. I think for trucks 3.9-4.1s are the ideal range for power off the line and towing and such.
keep the 3.55s, its not a big difference and its certainly not worth the money to change unless you need a drastic gear change for something. These trucks don't feel like 390hp because they're not.
If they are not 390HP then tell us the real number and your source of that information.
__________________
2009 Ram RCSB 5.7L Hemi Sport 4x4, 3.92LSD, 275/60R20 All season on 20x9" Chromed Aluminum wheels, Tow package, 506W Alpine premium 7 speaker sound, buckets,center console shifter.
They are 390 hp at the crank, not the wheels. The drive train soaks up a lot of power.
Otherwise, we can all sue Dodge for false advertising.
LOL that sounds right too, I had 2 truck lengths by 60 or so. I will admit he had the weight disadvantage..... but then thats why I bought a RC. I haven't seen a RC Tundra anywhere. If I do I will run it, win or lose for sure it will be a fun match - I don't think I can lose much worse than I did with the Vette
__________________
The advertised hp is different than the actual hp to the wheels, it varies between vehicles and unfortunately its usually extreme with dodge. They get there hp numbers staright from the flywheel. You put this thing on a dyno and it will pull around the advertised hp of the 3rd gen hemis.
My last truck was an 08 cummins with 350hp...lol it pulled under 300 on the dyno. I've seen the same with this truck
__________________
2009 Fiat Laramie Quad Cab 4x4
Thats ok Blown287 is going to hook me up with a blower and help me get the fuel mapping right. I dont think i want 14lbs of boost though, i dont have that much faith in the bottom end of these engines. Are our hemi's 2 or 4 bolt mains? Didnt they up the compression in 2009? Hell considering the state of the auto industry its probably got a plastic crank.
Lee
I once saw a dyno sheet on an 07 qc hemi 4x4 which were supposedly 360ish showing 245 at the wheels. I know you guys are going to laugh at that but that's what I saw. Also I think dodge/chrysler whatever you want to call them have allways had problems getting the power to the road. my.02
