DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 4th Gen Ram
4th Gen Ram 2009+ Rams
Thread Tools Search this Thread
  #21
Old 10-08-2009, 10:30 PM
matcad605 matcad605 is offline
Default Fog Lights Part Number
New to site. Only had my 2009 Ram for three weeks now and just installed the fog light kit. I agree, cut out the plastic block out cover. Much nicer look. The part number of the kit is 82211694AB. If you get it at the dealer, they take about two weeks. Least mine did. All I have to do is take it in to have them programmed, which the service manage said he would take care of it.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 10-17-2009, 10:27 PM
u8racing u8racing is offline
So I installed the fog lamp kit, but when I took the truck to the dealer they are having a hard time programing the truck to turn them on. Ive been told twice by the dealer that the truck software is newer then the Starscan unit software they have. The dealer scanner tool can see them and there connected correctly, just cant get them to program.
The truck is an 08/08 build, hard to believe that there scanner tool software is older then that.
I'm thinking that I may need to try a different dealer. Anyone else have this problem?
  #23
Old 12-29-2009, 10:55 PM
AkaReaper AkaReaper is offline
Let me get this straight, you install the lights, switch and you have to go to a dealer to have them program your truck for them to work? Any other options to get these to work?
__________________
2010 ST, Quad Cab, 4X4, Only mod so far is chrome wheel skins over the 17" steel rims.
  #24
Old 12-29-2009, 11:11 PM
08RamMan's Avatar
08RamMan 08RamMan is offline
Vehicle: 2008 Dodge Ram QC
That's how the 2006-2008 are as well...when I added the OEM kit, I then had to go to the dealer and they program the PCM with the StarScan to activate the fogs. Weird, but true....
__________________
Thanks,
Greggo
Magnaflow, 4.10s, K&N, HID, Hella, etc......
  #25
Old 12-30-2009, 11:20 AM
Maybe a bull bar and some other lights are in the works instead. Cost will end up about the same. Dang.
__________________
  #26
Old 01-28-2010, 01:04 PM
flatlander68 flatlander68 is offline
Vehicle: 09 ST 4X4 QC
Quote:
I assume your state doesn't require a front license plate ?
I just found out after buying the kit that my front plate will block about 1/3 of each fog light.
  #27
Old 01-28-2010, 11:25 PM
sneeks's Avatar
sneeks sneeks is offline
Vehicle: 09' Ram 1500 SLT 4x4 5.7L Hemi, 09' Pontiac G8 GT, 6.0L V8
The issue that you are having with your dealer is that they havent went to corp. and updated your VIN with the LPN (fog light) code. Starscan also has to be used wifi in the dealership to update your truck on the database before it will accept the programming.
Btw. I skipped these baby fog lamps and did the whole front end conversion. Happy with the results. But, be prepared to spend 700$ on the stuff to convert it, and another $49.95 @ the dealership to activate them in your truck. (because of the high-beams kill fog lamp feature the computer uses)
__________________
2009 Dodge Ram - 5.7 Hemi - Silver SLT 4x4
Mopar Step Bars / Bakflip G2 / Rhino spray in liner / Mopar Chrome bug shield / Chrome Billet Grille / Chrome Front Bumper with Fog Lamp Conversion
Chrome Dual Cut-Out Bumper Conversion / Dual Exhaust Conversion - Magnaflow 16870
  #28
Old 01-30-2010, 04:03 PM
Quote:
Originally Posted by devile View Post
I left the plastic peice in but cut holes in it, looks a lot cleaner, but had to do lots of trial and error in cutting... At the time i installed the tow hooks too, again, just cut the plastic to go around them. I've seen a few installed by dealer, and they just trash the plastic thing...
Devile
sent you a pm.
  #29
Old 02-02-2010, 04:25 AM
devile's Avatar
devile devile is offline
Vehicle: 2009 Dodge Ram 1500 Crew SLT
flatlander - got it...
Also wanted to add, as far as I know, the computer control on these trucks is intese... without the computer knowing that it has foglights, it won't even look for the switch to activate the wires it doesn't htink it has installed to be powered... That is why dealer needs to program... Someone should get into 'hacking' these new systems, i can only imagine what you could do with the truck with the software know how...
__________________
09' Crew SLT Black, 4x4... Added: Mopar Fog Light kit, Bug Deflector (hood), LiteRider Tonneau, Tow Hooks, (non-channel) vent visors. Soon to add: FBB, Mud Flaps and some sort of running board/step...
Tags
1500, 2006, 2008, charger, dodge, factory, fog, install, installation, installing, kit, light, lights, pcm, ram, viper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
