DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 4th Gen Ram
4th Gen Ram 2009+ Rams
Thread Tools Search this Thread
Old 11-01-2009, 12:38 AM
Bobba Booey's Avatar
Bobba Booey Bobba Booey is offline
Vehicle: 2009 Ram CC Hemi
Default Mufflex 14" Installed (Review + Pics + Video)
Single in/out Mufflex 14" muffler from Muflex Performance Exhaust.
Quality: The muffler is a magnaflow muffler retrofitted for the Ram. It already has extension pipes welded on, so there is no cutting or welding required. The welds are decent, not the best I've seen but still pretty good. The mufflex has a polished finish, which gives it a little bit of bling but it doesn't matter because no one will ever see it.
The Magnaflow muffler is a straight-through perforated design. It is very free flowing, much better than the stock muffler.
Installation: It was pretty straight-forward. The hardest part was removing the stock exhaust. The nuts on the stock hangers are on there pretty tight, but it's manageable. First step is to loosen the stock hangers on each side of the muffler.
After loosening the stock hangers you can remove the rear section. It helps to twist back and forth to help generate power to slowly slide the rear section out. The fit is pretty snug, but twisting back in forth will allow you to remove it a little bit at a time. Once the rear section is removed use the same twisting motion to remove the stock muffler. Be careful once the stock muffler is removed because it is heavy and you don't want it to fall on you. Here's what everything looks like after moving the stock muffler.
After removing everything I also took a few pictures of some of the stock components, for those who are interested. Here's some pictures of the stock catalytic converters and the incredibly restrictive y-pipe. I had no idea the y-pipe was this restrictive. I might change that in the future.
Now install the Mufflex muffer. The fit isn't perfect (as other's have noted). The front end fit good and there were no issues. You can tell it doesn't match perfect to where the stock muffler lined up, but there is no leak, so I don't care.
The rear side of the muffler is a different story. The fit was very poor and I can not manage to get the rear section to fit properly. There is a small leak as a result. I tried for a long time but couldn't manage to fix the leak. I tried to relocate the clamp to different spots, but it did not fix the leak. I also tried driving it for a week and working on the leak issue again, but still no luck. I will eventually take it to an exhaust shop and have them give it a try, and if they can't fix it I'll have them weld it.
Sound: Mufflex describes this size muffler as a 9 out of 10 on a loudness scale. It is much louder than stock, but I wouldn't rate it as high as a 9, more like a 7 or 8. I was looking for a loud exhaust, so this was actually a little disappointing. The sound is still very good and the exhaust note is very smooth. It has gotten louder as the muffler has broken in, which is a good thing. In the cabin the sound is very tolerable, but I know some people don't want to hear their exhaust in the cabin, so they would probably be happier with the 18 or 24 inch muffler.
MDS: I was a little nervous about how the exhaust would sound while in MDS, based on other reviews. I have to say the sound it not good, IMO. When MDS kicks in there is no doubt about it, it's very apparent. The sound gets very deep and there is a lot of drone. At certain speeds the sound reverberates and gets annoying. When driving mostly city, I prefer to drive with the truck in 5th on the manual shifter so MDS won't activate. When I drive on the freeway I put it back into full auto to help with the gas mileage. The MDS issue might not be as bad on the larger muffler (18" and 24"), but with the 14" muffler it's bad.
Performance: I didn't get any dynos done, so I have to go by the reliable butt dyno, which feels like there is a small power increase. I didn't really expect much and did the mod mostly for sound, so any power increase was a bonus. The only slightly objective data I have it that now I can break the tires loose from a dead stop, which didn't happen on the stock muffler (thanks to 3.21 gears).
Overall: I would give this exhaust and 8 out of 10. The exhaust sounds really good and makes your foot turn into lead, dunno why. The fitment could be better and the MDS issue might be a big turnoff to some. I would recommend this setup to someone who likes loud exhausts and wants a nice DIY option.
Now, what you all really want, the video. It's kinda long but I wanted to include a nice before and after comparison. Enjoy.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
09 Hemi Ram Crew Cab // Mufflex 14" // Bakflip G2 // Bedmat // Nerf Bars
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-01-2009, 01:59 AM
nt6977 nt6977 is offline
2009 Dodge Ram 1500
Vehicle: 2009 Dodge 1500 4X4 Sport
Thanks for the review. You did a real nice job on the comparision video. Now I want one...lol.
__________________
My new Girlfriend...lol.
Old 11-01-2009, 05:56 AM
tombogue09's Avatar
tombogue09 tombogue09 is offline
Thumbs up
Very nice job
__________________
2009 Fiat Laramie Quad Cab 4x4
Old 11-01-2009, 01:22 PM
crod crod is offline
Vehicle: 2009 dodge ram 1500. quad cab 4x4 sport. sunburst orange. 20" chrome clads,3.55 rear end.
yeah im with you on the sound. i would say 7. its actually perfect for what I wanted. just loud enough to know u have some kind of exhaust. not TO loud inside the cab. sounds good when your getting on it. have driven by all kinds of cop's. all situations. none of em even payed any attention. PERFECT..
mine fit up perfectly though...
Old 11-01-2009, 01:32 PM
94rt10ohio's Avatar
94rt10ohio 94rt10ohio is offline
Retired Administrator
2004 Dodge Ram SRT-10
My Garage
Vehicle: 94 Viper RT/10
Send a message via AIM to 94rt10ohio
It will get louder, mine did.
__________________
04 Ram SRT-10<--Click For Sale PM for details
09 Ram 4x4<--Click
Old 11-01-2009, 03:04 PM
War Horse's Avatar
War Horse War Horse is offline
Vehicle: 09 RAM 4x2 Bright Silver Sport
Awesome review.
I've got the 14 on my Sport. It will get louder, but nothing crazy. I'd say after it's worn in a little it'll sound closer to an 8. I totally agree with you on the 14 and MDS. It sounds like utter crap. Like you, I tend to drive in the city with it in manual 5th and then only let the MDS kick in on highways.
__________________
2009 RAM 4x2 Brilliant Silver Crew Cab Sport
Mods: Dodge Nerf Bars, 20% tint, iPhone Cable, Flowmaster Super 40, Line X, TRX Grille, Debadged, Weathertech Digifit, Leer 700 Hard Tonneau, 4.10 gears, & Auburn LSD
Next Mod: Superchip
Old 11-01-2009, 08:14 PM
I've had the muffler on for a couple of weeks and the sound has increased slightly. I really like the sound and now the truck sounds like it has a Hemi.
__________________
Old 11-01-2009, 11:33 PM
BubbaRadioNetwork's Avatar
BubbaRadioNetwork BubbaRadioNetwork is offline
Vehicle: 2009 Ram TRX4 Hemi Crew
Bobba Booey Bobba Booey! Sounds good.
__________________
'09 Ram 1500 Hemi TRX4 Crew Inferno Red
Bucket seats, sunroof, TorzaTop, hood deflector, Mufflex 14", Jason Cyber cap
Old 11-02-2009, 06:28 AM
nickahern1's Avatar
nickahern1 nickahern1 is offline
2006 Dodge Ram 1500
Vehicle: 09 hemi ram
nice truck and great review. thats probably the best review video i have ever seen for any exhaust. i am glad i someone with the single stock exhaust and the mufflex posted, most have the dual. Perfect sound for the hemi.i was going to get the cherry bomb vortex muffler and retrofit it all up but i like magnaflows alot so now i am Going to have to order this kit soon, however im going to do something with the exit cause i do not like the way the stock tailpipe exits at all. Alls i got to do is sell my chrome mopar bedrails and nerf bars..
__________________
2009 dodge ram rcsb Hemi
diablo predator
thats all for now but more soon to come....
Old 11-02-2009, 04:40 PM
Oosik's Avatar
Oosik Oosik is offline
Vehicle: 2009 Dodge Ram 5.7L HEMI "Lone Star"
I was slightly disappointed the 18" wasn't louder at idle, but I'm happy with it. Not to loud to be obnoxious but when you step on it it's noticeable. The MDS is bad on the 18" so I hate to think what it's like for the 14". I think mine gets quieter after it warms up, it starts up in the mornings with a roar but dulls down after driving around a bit. Maybe I should have gone with the 14".
Nice review though Bobba Booey.
__________________
Airaid MXP Intake, 18" Mufflex Magnaflow Muffler
Tags
exhaust, magnaflow, muffler, mufflex
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
