-------------------> 2-pairs 4 total - 3.5" CATZ Auxillary Lights
I have 4 individual CATZ Aux lights with wiring harness.
Looks like 3.5" lens and 3" depth
Perfect for a light bar!
All 4 have been shaved down for clearance on an install. I bought them like this and never used them. they appear to be sealed up due to a tiny hole from over grinding. You can just put more RTV or slap some JBweld over the top for something even more permanent. OR, you could flip them and the grind will be underneath(CATZ on lens will be upside down if that matters)
CATZ is a solid, well built light. Glass lens, quality reflector, Diecast Alum housing and sturdy mounting bracket.
I have one wiring harness to go with these. You can tap off the line for the other 2. Harness includes a relay and a rocker switch.
The bulbs...?? I'm not sure what they have in them. I think one set is 100W Purple or something. They are very bright. Extra set of bulbs included. Again, I don't know what wattage they are as I didn't bother taking them out to look at them.(Box is not what they are)
Selling all 4 for $50 shipped. Includes everything. I'm not going to split anything up. All or nothing. Priced plenty cheap enough.
List of what is included:
FOUR...4...Individual Lights
4 mounting brackets
3 sets of bulbs (two are installed and 3rd are in the container)
Complete wiring harness
$50 for everything is dirt cheap.
For $5 more I will include an additional relay/fuse combo if you think you need/want.
4 mounting brackets
