I just installed a new alpine deck and got everything going but I dont have any sound comming from the speakers other then the aftermarket sub. I got a harness from Bestbuy and hooked everything up but cant figure out why im not getting sound. I searched everything tried a few things nothing worked. the12volt.com didnt help . anyone know what to do? 05 dodge ram 1500 4x4 reg cab infinity system.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
Sponsored Links
Registered users do not see this ad. Click here to register for free!
i have an 04 and have the same problem. i called scosche and they told me to run all new speaker wires from the deck to the doors. you have to bypass the factory amp. i would think that some one has encountered this before and solved it. i took the brown wire and plugged it into the blue/white wire for the aftermarket amp remote and i got sound the deck worked awesome but all other electronics in my truck failed. no dash cluster or anything. my dash said no bus. so i unhooked it and everything is back to working order still no sound. i hope someone chimes in and fixes this.
__________________ 04 LowHemi Sport
BTC #103~~Lower Class #4~~HTC 19 Lower Class Club(JOIN)
You're not powering up the factory amplifier. There have been a few other topics on this, but there is no need to bypass the amp. Blue with white tracer is your factory amp turn on wire. This needs to see +12v when the head unit is kicked on. The brown wire was NOT the correct wire to hook up btw.
__________________ Mobile Electronics Certified Professional - Advanced Certified CEA 161312
i remember on mine when i hooked my aftermarket deck up it did the same thing....i remember i think it had to do something with the anttena because mine got power for the cd player through the attena...i really wish i could remember what i did lol
Yellow = +12v Constant
Red = +12v ACC
Black = Ground
White, White/Black = Front Left +/-
Grey, Grey/Black = Front Right +/-
Green, Green/Black = Rear Left +/-
Violet, Violet/Black = Rear Right +/-
Blue = Power Antenna
Blue/White = +12v Amp turn on
Orange = Illumination
Orange/White = Dimmer
Everything is color coded if you're using a factory adapter harness. Not rocket science.
i know its not rocket science. i had the blue/white wire hooked up from the start and it was a no go. i was just playing around when i hooked up the br wire. the is something about the amp being controlled by the bus system. so the 04s and up dont just plug and play. effin computers
