Hey fellas, i have a 4 channel amp. and i am wonder what is the best way to connect it to my DVC sub.
I only have one sub. and the box only has one of those input things.
Any help would be appreciated, Thanks.
Did you buy the amp brand new? If so, simply look in the instructions to figure out how to wire them up....most amps generally will use one positive from one side....and one negative from the other side for a single sub/mono hookup....it's really not that difficult....
Well, you can bridge a four channel amp to TWO channels. Use the outer positive and outer negative terminals only for channels 1/2, and 3/4. You know have two channels...to drive the DVC sub...you'll need two terminal cups...wire each one up to a bridged channel
