Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Installed a radio and it wont turn on
Old 05-28-2014, 05:56 PM
roggerrabbit87's Avatar
roggerrabbit87
roggerrabbit87 is offline
Default Installed a radio and it wont turn on
i just installed a radio on my 1996 dodge ram 1500 and the radio wont turn on at all, i already checked the fuse for the radio.
Old 05-29-2014, 12:16 AM
gerry92's Avatar
gerry92
gerry92 is offline
Welcome! Have you double checked the power connections?
Old 05-29-2014, 08:57 AM
roggerrabbit87
i double checked everything, i used a converter so i didnt have to cut any wires i just had to plug the converter into the truck and then the wires were pre cut so i just had to put the color with the right color.
Old 08-20-2014, 09:06 AM
Squints's Avatar
Squints
Squints is offline
You might need to run an additional 12v acc wire to the fuse block for power. I had to do this when I put an aftermarket deck in mine
Old 09-19-2014, 04:50 PM
cudajim's Avatar
cudajim
cudajim is offline
Make sure the unit is grounded, especially with mopar radios.
Old 10-18-2014, 01:02 PM
kyubikai's Avatar
kyubikai
kyubikai is offline
Default Wired up? Everyone's got some sort of electrical modification. Let's hear about it he
I try averything but not thing.
Old 10-20-2014, 11:33 AM
jkeaton is offline
Dodge Forum Administrator
If you have power and ground to the radio and it is not coming on, then the radio is defective or there is an internal fuse blown. Is this an aftermarket radio or an OEM out of another vehicle?
Old 01-04-2015, 03:05 PM
synoptic12's Avatar
synoptic12
synoptic12 is offline
* You cannot interchange high speed bus models compatible decks with low speed models. Some vehicles have a high speed computer bus and others have low speed. They will not work properly. Furthermore, the code has to be reset at the dealer.
Quick Reply: Installed a radio and it wont turn on
