Aftermarket confusion
After debating between a stock REC navigation deck and an aftermarket deck for my 2007 Dodge Ram 3500, I've decided to go with aftermarket for all the newest up to date features.
Here's the problem:
What do I need to make it compatible with my single din cd changer deck?
I am referring to harnesses and such (I will obviously need the double din bezel, navigation antenna, and backup camera).
I will likely be buying a Pioneer AVIC-X940BT. What do i need to make this work with what I have right now? There are so many harness options on ebay that make things confusing.
Also, there are some on there that are goijg for over $400. Really? That's probably more than the deck. if that's what I have to spend just on the harness then I'll just keep it as is for now.
Here's the problem:
