Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Cool Dodge Door lights
Old 03-31-2015, 05:25 AM
Aussie37's Avatar
Aussie37
Aussie37 is offline
Default Cool Dodge Door lights
Hello,
I found these lights on fleabay.
Shines on the ground when you open the door... I bought 4 x for my '37 Dodge.
Item #3
http://www.ebay.com.au/itm/Mt-4th-Ge...item2c98dbe9c9
Cheers
Old 03-31-2015, 07:30 AM
jkeaton is online now
Dodge Forum Administrator
I've seen those. How did you wire them?
Old 04-02-2015, 07:06 PM
Aussie37's Avatar
Aussie37
Aussie37 is offline
There's a red & black wire in the flex.
Red to + black to -
I just parallel wired to existing door light circuit.
If you have an interior light circuit that switches ground through the door switches, then you need red to a + source (fused of course)
and the black wire can go to the door switch wire. Simple. Open the door, the door switch makes ground, light comes on.
Another thing I am considering is liberally coating them (what's inside the door cavity) with plasti dip "liquid electrical tape"
I use this in my job to protect PCB's from water damage in battery powered tools.
https://www.plastidip.net.au/liquid-tape-electrical
Its an Aussie web site, however I'm sure this is available globally, or something like it.
Quick Reply: Cool Dodge Door lights
