Does anyone want a Dodge diesel option?
Although diesel costs more, diesels last longer if well maintained. Besides, who wouldn't love rolling coal in a little Dodge car? I think select models with a diesel option would definitely benefit Dodge economically. I don't think it would be a HUGE hit, but heck, it would increase revenue a heck a lot more than what they have as it is.
As an aside, the newer Common Rails do have a tendency to cause major damage. An injector fails in a 12v Cummins, you replace it and keep driving. An injector fails in a CR, and you're likely looking at a melted piston or two. And the DPF/EGR has lessened reliability, but I still see diesel as a superior option.
I've lost three CR Cummins engines in two years; the 03 lost two and the 07 lost one. The 03's first failure was injectors (hard start symptom), then the shop replaced them and somehow screwed it up. End result was two melted pistons under 100 miles on replaced injectors. Year and a half later, fluke oil pump failure tossed a rod through the block. The 07 was my fault; playing with a VERY agressive rail pressure box melted two pistons. It still ran and drove though
Diesel in a car is great. I drove several VW Rabbit diesels years ago, and the VW TDI really scoots. Dodge should proceed, but they can't afford to *****-foot around. They need to go after it and do it right. Turbo-diesel or nothing. It's hard to get good performance from an N/A diesel. My maintenance costs weren't high at all. Engine held the same amount of oil as the VW gas engines. In fact, VW's diesel was also a gas conversion...done right.
Dodge, chrysler. ford. gm and every car brand in north america is messed up.
The rest of the commom world has been running diesel engines for years upon years. ,
New engines in HD duty trucks are garbage with all the emisson crap built into them, thats why thier is a run on gasoline powerd engines in north america.
as mentioned,you take a 65mpg jetta and down grade it to 45 mpg to burn more cleaner flue to get less mpg is a joke.
I'm currently shopping VW TDI's, namely the new Golf. Chevy is apparently going to offer a diesel in their Cruze in a few years. If Dodge/Chrysler would offer a good diesel in a low-priced, stylish ride, the Golf wouldn't even be on my list. But by the time they decide to, I'll probably have a TDI of some sort so...damn.
And it HAS to have a manual option Dodge/Chrysler!
In Europe Chrysler/Dodge/Jeep vehicles come with diesel engine options that aren't available in NA.
EG:
Jeep Wrangler with a 2.8L diesel.
http://www.jeep.de/wrangler_unlimite...crd/index.html
Here's an example of a used Chrysler Voyager (remember that van name) with a 2.8L diesel.
http://www.webmobil24.com/web/de/cjd...style=chrysler
In Europe, the Chrysler mini-vans are now being marketed under the Lancia product brand.
http://www.lancia-services.de/iaa2011/
Another interesting fact is that all of the Diesel engines used by Chrysler in Europe are designed and built by an Italian company called VM Motori., which is now co-owned by GM and Fiat. Fiat bought 50% ownership from Penske Corp!
http://www.vmmotori.it/en/01/01/index.jsp
In fact a good majority of Chrysler engines have come from various different sources such as the 4.0L straight 6 in the Jeeps was an AMC designed engine.
EG:
