SRT-4 spec sheet
SRT-4 spec sheet
I found the spec sheet. This thing's gonna weigh 3189#. [sm=smiley30.gif]I was thinking about an SRT-4 for autox. Not any more, no wonder it has 300HP! Anyone have a low mileage '95 neon without power steering and a five speed? [sm=gears.gif] Actually, it will likely go against mustangs so it will probably do fine in class. [sm=lol.gif]
2007 Dodge Caliber SRT4 – Preliminary Specifications
All dimensions are in inches (millimeters) unless otherwise noted.
GENERAL INFORMATION
Body style............................................. .................................................. .....................Five-door hatchback
Assembly Plant............................................. .................................................. ..................Belvidere, Illinois
EPA Vehicle Class............................................. .................................................. ....................Compact Car
ENGINE: 2.4-LITER DOHC 16-VALVE I4 WITH VARIABLE VALVE TIMING, TURBOCHARGED
Availability...................................... .................................................. .................................................. .....Std.
Type and Description....................................... ........... Four cylinders in-line, tuned intake manifold with
Electronic Active Charge Motion Control valves, dual counter-rotating balance shafts
Displacement .................................................. .................................................. ..144 cu. in. (2360 cu. cm.)
Bore x Stroke .................................................. .................................................. ......... 3.46 x 3.82 (88 x 97)
Valve System............................................ ..............Chain-driven DOHC, 16 valves, electronically controlled
dual Variable Valve Timing, direct-acting shimless mechanical bucket tappets
Fuel Injection .................................................. ........................Sequential, multi-port, electronic, returnless
Construction...................................... .......... High-pressure die cast aluminum block with dry iron liners,
cast aluminum cylinder heads, cast aluminum ladder frame, forged steel crankshaft
Compression Ratio .................................................. .................................................. ..........................8.6:1
Power (SAE net, estimated)........................................ ........300 bhp (223 kW) @ 6000 rpm (125 bhp/liter)
Torque (SAE net, estimated)........................................ ................ 260 lb.-ft. (352 N•m) @ 2000-6000 rpm
Max. Engine Speed............................................. ..................................... 6500 rpm (electronically limited)
Fuel Requirement .................................................. ....................... Unleaded premium, 93 octane (R+M)/2
Oil Capacity .................................................. ...........................5.0 qt. (4.7L) SAE 0W/40 Mobil 1 Synthetic
Coolant Capacity.......................................... .................................................. .........................7.2 qt. (6.8 L)
Emission Controls .................................................. ....................................Twin catalytic converters, dual
heated oxygen sensors and engine features
Max. Gross Trailer Weight .................................................. .................................................. ..................N/A
Estimated EPA Fuel Economy MPG City/Hwy............................................... ......................................22/28
TRANSAXLE: MANUAL, GETRAG DMT-6 6-SPEED
Availability...................................... .................................................. .................................................. ......Std.
Description....................................... ..............six-speed, overdrive,synchronized in all ratios, cable-operated,
four-plane shifter with reverse lockout ring
Gear Ratios
1st............................................... .................................................. .................................................. .......3.231
2nd .................................................. .................................................. .................................................. ...1.952
3rd .................................................. .................................................. .................................................. ...1.321
4th .................................................. .................................................. .................................................. ....0.971
5th .................................................. .................................................. .................................................. ....1.061
6th .................................................. .................................................. .................................................. ....0.886
Reverse .................................................. .................................................. .............................................3.831
Final Drive Ratio .................................................. .....................................Gears 1-4: 4.063, gears 5,6: 2.955
Overall Top Gear.............................................. .................................................. ....................................2.728
ELECTRICAL SYSTEM
Alternator .................................................. .................................................. ..........................................140A
Battery .................................................. .................................................. ........... 700 CCA, maintenance-free
DIMENSIONS AND CAPACITIES
Wheelbase......................................... .................................................. ...................................... 103.7 (2635)
Track, Front............................................. .................................................. ...................................59.8 (1520)
Track, Rear .................................................. .................................................. ..............................59.8 (1520)
Overall Length............................................ .................................................. ........................... 173.8 (4413.9)
Overall Width............................................. .................................................. ............................. 68.8 (1747.2)
Overall Height .................................................. .................................................. ....................... 60.4 (1533.1)
Ground Clearance .................................................. .................................................. .........................7.0 (178)
Frontal Area, sq. ft. (sq. m)................................................ .................................................. ...........24.5 (2.28)
Drag Coefficient .................................................. .................................................. ....................................0.4
Curb Weight, lb. -- estimated (kg )................................................. .............................................. 3189 (1447)
Weight Distribution, percent F/R................................................. .................................................. ........58/42
ACCOMMODATIONS
Seating Capacity, F/R .................................................. .................................................. ..........................2/3
Front Headroom without sun roof.............................................. ............................................... 40.0 (1015.6)
Leg Room.............................................. .................................................. ................................. 41.8 (1061.5)
Shoulder Room.............................................. .................................................. .......................... 54.2 (1377.8)
Hip Room.............................................. .................................................. ................................. 52.2 (1325.3)
Seat Travel............................................ ......................................Driver – 10.2 (260), passenger – 10.2 (260)
Recliner Angle Range, deg. ...............................Driver – up to 88, passenger – (76 fold flat/88 non-fold flat)
SAE Front Volume Index, cu. ft. (cu. m.)............................................... ........................................52.4 (1.485)
Rear Seat Headroom.......................................... .................................................. ........................38.9 (989.3)
Leg Room.............................................. .................................................. ....................................35.6 (905.1)
Knee Clearance .................................................. .................................................. ...........................0.9 (21.8)
Shoulder Room.............................................. .................................................. ......................... 53.4 (1357.2)
Hip Room.............................................. .................................................. ................................. 49.6 (1260.8)
SAE Rear Seat Volume Index, cu. ft. (cu. m.) .................................................. .............................42.8 (1.212)
SAE Interior Volume, cu. ft. (cu. m.) .................................................. ..........................................95.2 (2.697)
Cargo Volume Indexes.
Rear Seats Up, cu. ft. (cu m.)............................................... .................................................. ......18.5 (0.525)
Rear Seats Folded, cu. ft. (cu. m.) .................................................. ...............................................48. 0 (1.36)
EPA Interior Volume Index, cu. ft. (cu. m.)............................................... .................................. 113.9 (3.225)
Liftover Height .................................................. .................................................. .........................27.6 (701.4)
BODY
Layout .................................................. ......................................... Transverse front-engine front-wheel drive
Construction...................................... .................................................. ............................ Unitized steel body
SUSPENSION
Front .................................... Independent MacPherson strut, coil spring over gas-charged shock absorbers
and stabilizer bar
Rear .................................Multi-link-link independent with coil springs, link-type stabilizer bar, gas-charged
shock absorbers
STEERING
Type.............................................. ............................................. Rack and pinion with hydraulic power assist
Overall Ratio............................................. .................................................. ..........................................16.6:1
Turning Diameter (curb-to-curb) .................................................. .............................................39.6 ft. (12 m)
Steering Turns (lock-to-lock) .................................................. .................................................. ................2.76
TIRES
Size and Type .................................................. .................................................. ..P255/45ZR19 Performance
Mfr. and Model .................................................. .................................................. ...........................Goodyear
Revs per Mile (km) .................................................. .................................................. ....................765 (1231)
WHEELS
Type and Material .................................................. .................................................. ...............Cast Aluminum
Size .................................................. .................................................. ..............................................19 x 7.5
BRAKES
Front
Size and Type............................13.3 x 1.1 (340 x 28) vented disc with 2.2 (57) dual-piston floating caliper
Swept Area .................................................. .................................................2 23.52 sq. in. (1442.12 sq. cm)
Rear
Size and Type............................11.8 x 1.39 (302 x 10) solid disc with 1.4 (35) single-piston floating caliper
Swept Area.............................................. .................................................. ........138.64 sq. in. (894.6 sq. cm)
Power Assist Type.............................................. ..................................... 10 (254) single-diaphragm vacuum
Four-wheel Anti-lock.............................................. .................................................. ............................... Std.
Electronic Stability Program… .................................................. .................................................. .............. Std.
GENERAL INFORMATION
Gear Ratios
ELECTRICAL SYSTEM
ACCOMMODATIONS
BODY
SUSPENSION
and stabilizer bar
shock absorbers
STEERING
TIRES
WHEELS
BRAKES
Front
Rear
RE: SRT-4 spec sheet
Yeah, hopefully they will add an AWD version to the lineup so it could compete with the Impreza WRX STI and Lancer Evo.
I'm hoping they add a 5 speed auto or a CVT auto option to it as well, they do and I may very well be trading in my Magnum for one, better performance, better fuel economy, lower loan payments and still a decent amount of cargo room and it looks great, the manual is the only thing making it a no-sale for me right now, the R/T has an auto but ther performance is going to suck on it, way to little hp for it's weight.
Trending Topics
These things will never be able to compete against a sti or and evo, they are just to heavy, even if you get a company to make a cf hood and rear tail gate, it might bring it down closer to their weight but if they do the same they will be lower and still beat them. Beside the real SRT-4 Neon's can beat an evo and a sti, and we just have fwd with lsd, and then there are some evo's and sti that will smoke a SRT neon. But stock for stock the others will beat the caliber in a race, just due to the weight
