i am looking at the following 4 speed for my 68 sperbee 383 car. here are the numbers the owner has given me and i am having problems figuring if this will work in my car. THIS TRANSMISSION HAS 23 SPLINE INPUT SHAFT. WE ARE NOT SURE WHAT THIS CAME OUT OF SO DO YOUR RESEARCH. THENUMBERS ON THE TRANSMISSION ARE: H3 C99129; ON THE SIDE COVER - C95664/5X06; TAILSHAFT - 6 20/C99126-3. can anyone provide help. also what size diamater is the input shaft for the 383 car?
thanks Jerry
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Not sure on the numbers you list (do not have a reference book on them). But the 23 spline is correct for 383 and non 440/Hemi vehicles. The A833's were the same internally across the car lines, the difference from A body, B body and E body was the tailshaft length. Your Bee will need the long tailshaft version.
One of the best places for 833 information is here http://www.brewersperformance.com/orderinfo.htm
They explain the numbers on all the pads.
The external looks are all the same the internals are not gear ratios and syncrs are different plus front bearing retainers
are not all the same. Main Bearings are different also from older to newer transmissions.
The tail shaft and housings as stated are different as are the shifter mount points.
Bryan
__________________
71 RoadRunner Owned and operated from 1975
My first Car and Love, Ask my wife
