DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > A Blast From the Past > Dodge Muscle Cars > Dart, Demon, and Duster
Thread Tools Search this Thread
Old 02-21-2008, 11:35 PM
IBQuig IBQuig is offline
Default 273 to 383 engine swap?
I have a 1966 dodge dart 270 convertable with a 273 engine. Will a 383 fit and if so, what problems will I encounter with this engine swap?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
IBQuig
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-22-2008, 11:30 AM
Horseapples's Avatar
Horseapples Horseapples is offline
Vehicle: 04' HEMI 2 door SWB
Default RE: 273 to 383 engine swap?
Yes and no. Yes, it can be done, Dodge did it at the factory in some GTS darts. No, you probubly dont want to try it. It is a huge ammount of work. You will need to change the "K" member first so you can mount the engine(finding a big block A-body k member is difficult) you need to change the torsion bars, brakes to accomodate the heavier engine, cut holes in the fenderwells to run headers(unless your incredibly lucky and find original 383 manifolds) change rear end to an 8.75in unit or dana 60 and add sub frame connectors to put up with the extra torque, re-locate the trans crossmember,to accomodate the longer big block trans and hand fab your exhaust. All in all, A 318/340/360 would be the way to go if your interested in more power. These engines are the same size as the original 273. The car is going to lose value with an engine swap, be sure to keep the original engine for later restoration.
__________________
Passin gas and haulin' ass!
Member: Over the Top Group
Old 02-25-2008, 12:29 PM
dodgebrothers dodgebrothers is offline
Agree w/ Horseapple...though I don't think Dodge tried it until '67 Dart which is slightly different engine bay. But the same issues as mentioned would need to be addressed. My 68 Dart was a 273 and now 383.
You might want to check w/ Schumachers, www.engine-swaps.com as they might save you the K frame swap (though not sure how popular the '66/383 deal) would be that they may have created mounts for it. TTI also does some very tight header configurations that may avoid fender wall cuts...did on my Dart. Definetly need to upgrade rearend to 8 3/4.
Good luck
__________________
Nothing beats a Mopar!
Old 03-02-2008, 07:34 PM
Thanks for the info.I really appreciate the feedback.
IBQuig
__________________
IBQuig
Old 03-03-2008, 10:55 AM
No problem. I still need to add sub frame connectors on mine, as I'm popping the rear window molding...[sm=bangbang.gif]
__________________
Old 07-03-2008, 10:04 PM
06blackdak 06blackdak is offline
pretty tough swap. The 66 has a smaller engine bay than the 67-69 Dart. I don't think anyone makes headers for a big block in that body style. I could be wrong thoug. Good luck.
__________________
This damn truck is making me want to by a Toyota!
Tags
270, 273, 383, engine, mopar, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
