Notices
Detailing Discuss detailing your ride inside and out here.
What's a Good Wheel Polish
Old 03-02-2005, 01:05 PM
Ram Job's Avatar
Ram Job
Ram Job is offline
Default What's a Good Wheel Polish
I just picked up a set of Boyd Coddington Smoothie II's but they are in need of some serious work. They are not pitted, they just look dull. Has anyone tried that Flitz Ball and their polish?
Old 03-03-2005, 01:58 AM
VegasHemi's Avatar
VegasHemi
VegasHemi is offline
Default RE: What's a Good Wheel Polish
I've used several different Metal Polish products, and all of them seemed to work well. There are two types of metal polish, one chemical and one has abrasive properties. I'd suggest if the wheels are just dull, look for a chemical polish. I have never used the "Flitz" ball, but I know others who have and their only complaint that I heard that after washing it, it looses it's effectiveness.
Old 03-03-2005, 08:20 AM
PearlStealthRT_TT's Avatar
PearlStealthRT_TT
PearlStealthRT_TT is offline
if the rims are chrome and have a dull finish...that usually means the plating is seperating from the steel....its the beginning of the end!!
Forutunatly for you...Boyd uses alluminum, usually a dull finish on an alluminum rim is only on the clear coat....heres your fix...
You can lightly sand the rims to get the clear coat off, then run ultra sand paper (1500-2000 grit...water sand only) on the whole rim...nearly to the priginal polished look (this takes a while...but its worth it!!) After that use either mothers or never dull (never dull is my preferance) polish on the whole rim. Then use prep-sol (found at most parts stores) to strip the film from the polish...this will actually make them gleam even better. Most people would then clear coat the rims....and BANG!! A brand new rim...GOOD LUCK!!
Old 03-04-2005, 01:33 AM
Ram Job's Avatar
Ram Job
Ram Job is offline
Thanks Guys,
I picked up a bottle of "Blue Magic" Metal polish and that did the trick. They look pretty good as new now!
Old 03-04-2005, 04:55 AM
71RoadRunner's Avatar
71RoadRunner
71RoadRunner is offline
If you need to remove rust, asphalt, tar, brake dust or oxidation, nothing I've found works better than Turtle Wax Chrome Polish.
Old 03-22-2005, 02:58 PM
ramit05's Avatar
ramit05
ramit05 is offline
I've had some pretty good luck with Wenol products. I purchased it online and it worked great. Here's a link if your interested.
http://www.autogeek.net/wenol1.html
Old 03-23-2005, 11:55 PM
Jason@autogeek's Avatar
Jason@autogeek
Jason@autogeek is offline
ram job- can you post a picture of the wheels?
Old 03-27-2005, 08:36 PM
71RoadRunner
Wenol is some pretty good stuff, especially with bare metals.
Old 05-16-2005, 04:25 PM
Rockadile's Avatar
Rockadile
Rockadile is offline
Simichrome is also a good abrasive polish. I picked it up at my local motorcycle shop.
Quick Reply: What's a Good Wheel Polish
