Notices
Detailing Discuss detailing your ride inside and out here.
Road Grime?
Old 03-14-2005, 12:03 AM
DakMan6704's Avatar
DakMan6704
DakMan6704 is offline
Default Road Grime?
I washed my truck quickly today as it was cold and breezy...but in the time I spent on it, I noticed little bits of black stuff on the fender flares and mostly the pass. side. Since the truck is black, its harder to see. Anyway, I was curious if anyone had ideas on how to nicely remove it, via clay bar, or polishes? Any help is appreciated...Thanks!
Old 03-14-2005, 12:07 PM
VegasHemi's Avatar
VegasHemi
VegasHemi is offline
Default RE: Road Grime?
Try getting some "Tar Remover" first. Chemically removing it will be the safest. If that doesn't work, try a clay bar.
Old 01-21-2006, 05:22 AM
2004 Hemi Quad's Avatar
2004 Hemi Quad
2004 Hemi Quad is offline
Tar remover from your Autostore
Old 01-21-2006, 06:44 PM
06ChargerSXT's Avatar
06ChargerSXT
06ChargerSXT is offline
Try peanutbutter seen it on TV some ware
Old 01-24-2006, 05:24 PM
Quacker's Avatar
Quacker
Quacker is offline
Try WD-40 it works
Old 03-02-2007, 12:20 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
I know its an old post but i see this often and is eaiser to obtain. some Reg unleded fuel in a spray bottle worked in with finger work fine then wipe clean with clean red shop rag. then rewax after finished
Old 04-20-2007, 03:21 PM
tinyfxds's Avatar
tinyfxds
tinyfxds is offline
Another good trick is to use an indoor carpet cleaner solution. I actually use my carpet cleaner with the attachment. It works great
Old 04-20-2007, 03:26 PM
Midnight Runner's Avatar
Midnight Runner
Midnight Runner is offline
I use LIFTER BUG & TAR remover. And it is safe on clear coat finishes.
Old 04-28-2007, 04:04 PM
DOHCgarrett t3
ORIGINAL: tinyfxds
never tried that ill have totry that
Old 05-26-2007, 12:34 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
wejust use oderless mineral spirits(paint thinner) and it takes the road tar and grime right off
Quick Reply: Road Grime?
