Hi all,
My '99 ram came with a set of aluminum bed rail caps. The problem is they were sitting in the sun for 9 years and they're heavily corroded. Instead of being mirror like, they are more of a greyish yellow color and give absolutely no reflection.
I bought some Mothers aluminum polish and went to work on them, but I can't get them shiny is I would like. What's the best way to polish HEAVILY corroded aluminum? Thanks in advance.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
If you're not livin' on the edge, you're taking up too much space.
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I use a standard chrome polish for mine, but I also use a power wheel and completly shred on the caps and the running boards to get them to shine. I have some aluminum polish laying around, but it doesn't do as good as a job IMO.
__________________
Mein Kampf- Yes, I have one of my own
Is now creating sigs Look
Red Truck Club Number 7
To vote in polls
1. Member for 30 days
2. 50 or more posts!
Does the polish turn black when you apply? If so it is not clear coated and I would use Wolfgang Aluminum Polish. If it doesnt that you have to treat it like paint. I would try M105 and M205 from megs
__________________
*HID Kit *15% tint *2'' Leveling Kit *KN Air Charged Intake *Custom CM Performance Exhaust *32.8'' BFG Mud Terrian *Black Taillights *LED Brake Lights *10'' Pioneer Shawllow Mount Sub
Waiting on a lift kit!!!
Yes the polish turns black when applied. The can of mothers alumnimum polish says it's supposed to turn black. I'll try chrome polish and the other products mentioned and see how it goes.
Is there something I can coat the aluminum with that will give it a little bit of gloss and protect it from the sun?
__________________
my wife uses 'barkeepers friend' for her aluminum pots and pans. Now I know this is for a car, but it does make them shine (it is an abrasive powder),
FF
__________________
Inertia big valve ported heads, Crower camshaft, Moto-blue underdrive pulley, AEM cold air intake, JBA exhaust headers, Magnaflow high flow catalytic converters, Magnaflow cat-back exhaust, Diablo predator sport tuner.
If it is that corroded, you might try rubbing compound. It has some stronger abrasives, but should not be rough. I like using Brasso myself. I ended up using Polishing compound on my nerf bars about two months ago because the base uses secondary water to run the sprinklers, and my truck was getting coated with lots of hard water deposits...
+ 1 on rubbing compound....worked great on my bed caps....also, i used a etching wheel cleaner on my nasty aluminum wheels and it worked great...i think it was eagle one...might give that a try
