Notices
Detailing Discuss detailing your ride inside and out here.
best buffer?
Old 03-02-2007, 10:34 PM
flamingpinhead's Avatar
flamingpinhead
flamingpinhead is offline
Section Moderator
Dodge Forum Moderator
Default best buffer?
I want a good buffer, capable of a good RPM range. I have experinece in using them as a detailer, we always used the DEWALT models. I have seen some 'bargin' models on ebay, but im not sure what Im looking at. We always spent the money on the brand product... Its 200 bucks seems like a lot to spend on one. What other models/brands are safe to look at? Thanks!!!
http://www.toolking.com/productinfo....bizrate=DW849R
Old 03-03-2007, 08:43 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
Default RE: best buffer?
that is a good buffer for your car. in fact its prolly the best one out there.
because you can set the max speed. I usualy run mine at a 3 or less. and you can change the brushes without taking the whole thing apart. im not sure what other models are out there, at least ones that are equal or better to the dewalt DW849. i paied $123 with shipping for a used one on e bay. http://cgi.ebay.com/ws/eBayISAPI.dll...;rd=1&rd=1
ame thing diffrent website for 189$
http://www.tylertool.com/dewdwheavdu...WkcZilKy0onXee--
I would not get a cheaper model unless its the same thing just refurbished.
Old 03-04-2007, 12:59 PM
MyFirstDodge's Avatar
MyFirstDodge
MyFirstDodge is offline
I first bought a used Makita 9227 off ebay and later upgraded to an AWESOME Metabo PE-125. At about 2-3 lbs lighter, this machine has gotten rid of the fatigue that 6 hours of polishing an RV will give you. For about $250 you get the buffer, with a 3 year extended warranty. If you polishing only your vehicle, it's probably not going to be worth it to buy this expensive of a model. As for the Makita, I never had any problems and mine was second hand.
-Shaun
Old 03-04-2007, 01:02 PM
MyFirstDodge
I upgraded to a Metabo unit this year. $250, 3 year warranty, and no fatigue when polishing an rv for 6 hours. If your only using this for your vehicle, a Makita or Dewalt will serve you well. I had a used Makita 9227C for 2 years before that with no problems.
-Shaun
Old 03-05-2007, 08:10 PM
flamingpinhead
Section Moderator
thanks fellas, think im gonna save a couple bucks and go with the dewalt
Old 03-06-2007, 12:54 AM
Hit_it's Avatar
Hit_it
Hit_it is offline
I have been using this one for the last month. It's been great everytime.
http://ww2.harborfreight.com/cpi/cta...emnumber=92623
Old 03-06-2007, 01:34 AM
MoparMJM's Avatar
MoparMJM
MoparMJM is offline
Personally, I am a Dewalt guy... all my power tools are dewalt. Except for one... my buffer... it is a porter cable. The only reason I went with them is because of the insance amount of good customer reviews on it. If you prefer Dewalt products that much, than get it, just make sure it has variable speeds.
if you have time check out autopia.org and just do some searchs for buffers.
Old 03-07-2007, 06:40 AM
mopar222's Avatar
mopar222
mopar222 is offline
get the hitachi, 5yr warr, and one of the most powerful motors o the market
Old 05-08-2007, 04:18 PM
07Ramjam's Avatar
07Ramjam
07Ramjam is offline
This is what I use:
http://www.meguiars.com/?pro-car-det...ction-Polisher
Its safe for the paint(wont burn) and with the right products does an excellent job.
Old 05-11-2007, 12:52 AM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Quick Reply: best buffer?
