Notices
DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
CPS testing procedure Avenger 1st Gen by bad venge
Old 08-17-2007, 06:05 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
Default CPS testing procedure Avenger 1st Gen by bad venge
If you can move the battery out of the tray a bit but leave it hooked up...unbolt the Crank sensor on the top of the trans at about 1 oclock. Leave it plugged in and use a sharp electical probe toprobe the weather pack connector being careful to slide it in next to the wire not into the insulation.
using a digital volt ohm meter like sears sells for twenty bucks and with the key on but engine not running...no prob right!...you should have nine volts on one wire, about 5 volts on another and next to nothing on the ground wire. hold something metallic up to the end of the sensor usually inside the trans...it should pull the 5 volts to zero. buy a new sensor if it is 9 ,0 and 0 and one of them pops up to 5 when you unplug it in the open air as described above.[/align]
Avenger1stGen
Old 08-18-2007, 12:29 AM
silvercoupe97's Avatar
silvercoupe97
silvercoupe97 is offline
Uber Moderator
Default RE: CPS testing procedure
Posted at the top bud.
Quick Reply: CPS testing procedure Avenger 1st Gen by bad venge
