Roe Cat/Muffler combo install 92-95 Dodge Viper by 94rt10ohio
Purchased Roe Racing exhaust kit.
http://www.roeracing.com/ProductCart...p;idproduct=33
Steps
1. Remove the sills
2. Hit the rusty screws on the clamp that holds the turn down on your existing muffler with some lube, this needs to come off in order to get the bolts out on the muffler hanger.
3. Remove both bolts on the muffler hanger.
4. Saws-all.... Cut the stock exhaust off in front of the cats right by the weld.
5. Use heavy sandpaper or a small rotatary tool to grind the rust off the pipe remaining.
6. Put some lube, I used WD-40, on the pipe you just cleaned.
7. Slide on the exhaust and clamp it down!!
8. On the old exhaust will be a piece of rubber you will need to use when mounting the new muffler onto the car. You will need to take the saws-all again to cut some nipples off the stock muffler in order to get the rubber off.
9. Slide the rubber onto the new muffler hanger and bolt up to the car.
10. Install and align the turn down. You will need to slide the sills on to align them. If Roe does not do it polish the turn down first, it is stainless steel.
Reinstall the sills.
It is litterally that simple! From what Roe told me if you have a 92 or 93 some welding is required.
DodgeViper
Steps
1. Remove the sills
DodgeViper
