Notices
DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
DIY daytona/SRT 10 spoiler removal
Old 06-03-2008, 05:16 PM
jonnymagnum's Avatar
jonnymagnum
jonnymagnum is offline
Default DIY daytona/SRT 10 spoiler removal
well I thought I would do a write up on how to remove the spoiler on daytona's and srt 10's.
first off you locate the two 10mm bolts that are just underneath the front of the spoiler
then once you take both of them out. you have to take 2 plastic clips off. so you can un hook the wire that attaches to
the spoiler.
Ram3rdGen
Old 06-03-2008, 05:28 PM
jonnymagnum
Default RE: DIY daytona/SRT 10 spoiler removal
after you unhook both sides, you just have to lightly tap the spoiler back about an inch
before
after
do one side at a time. you might have to hit it a lil bit hard if its the first time the spoiler has ever came off. and just use the palm of your hand.
next all you have to do is lift up the spoiler both sides at once. you may need 2 people for this, but 1 person can do it. I'm only 5'5" and can do it just fine
and this is all that holds it on.
so to reinstall it, all you have to do is line up the hole in the back to the pin thats sticking up, and lightly tap the spoiler forward to lock it in. then make sure the bolt holes line up and tighten up the bolts, then hook the wire back up and the retainer clip and your all set.
before
after
this is my first DIY, so a mod can sticky this and change anything if needed.
Quick Reply: DIY daytona/SRT 10 spoiler removal
