How To Put Racing Stripes On Your Vehicle by casper
on
Thanks to casper for this article!!
Please Read DodgeForum.com's Disclaimer
Materials Needed:
Rubbing Alcohol
Vinyl - available at your local sign shop
Spray Bottle with water and a few drops of soap
Rubber Squeegee
Pen
Ruler
1) Measure and cut vinyl to the sizes needed.
2) Clean area where the strips are going to go with rubbing alcohol.
3) Measure and mark where you want the stripes to go.
4) Spray area where vinyl is going to go with water/soap mix.
5) Peel and spray vinyl with water/soap mix.
6) Lightly lay the vinyl adhesive side down and carefully position. Vinyl should be able to be moved around, if not carefully peel up and spray with more water/soap mix.
7) Once you have the vinyl positioned correctly spray the top with the water/soap mix and gently work the air bubbles out from the center to the edges.
Enjoy!!
123abc
Materials Needed:
Rubbing Alcohol
Rubber Squeegee
Pen
Ruler
Enjoy!!
123abc
