Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
I have a stock radio question?
Old 10-30-2014, 05:48 PM
JakeHasA97Ram's Avatar
JakeHasA97Ram
JakeHasA97Ram is offline
Default I have a stock radio question?
Okay so, I have a dodge avenger radio, and I need to know if someone can help me find a stock wiring harness or can give me a brief explanation of it? I'm trying to figure out a way I can make it work in my 1997 dodge ram 1500 and it fits it's just the plugs are different... And even if I got it in there I don't know how I would hook my subs up to it.. I'm so lost when it comes to this stuff, I just started messing around with it. The radio came out of a 2008. Any help would be greatly appreciated!
Old 10-31-2014, 09:33 AM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
Battery YELLOW/RED (+) RADIO HARNESS
Ground BLACK/WHITE (-) RADIO HARNESS
LF Speaker (+) GRAY/VIOLET
LF Speaker (-) GRAY/YELLOW
RF Speaker (+) DARK GREEN/VIOLET
RF Speaker (-) DARK GREEN/YELLOW
LR Speaker (+) GRAY/LIGHT GREEN
LR Speaker (-) GRAY/DARK GREEN
RR Speaker (+) DARK GREEN/LIGHT GREEN
RR Speaker (-) DARK GREEN/GRAY
but you will need the harness from the 08 venge
http://metraonline.com/part/71-6522
that's also assuming that it's not the upgraded amplified system
Quick Reply: I have a stock radio question?
