Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Electronic Throttle Control System
Old 05-11-2009, 12:33 PM
jdcaliber07's Avatar
jdcaliber07
jdcaliber07 is offline
Default Electronic Throttle Control System
I have had my 2007 Caliber for 3 years, this Sept. On Friday, my car would not start, and the light indicated there was an issue with the ETC. For the last 2 or so months, when I would turn on my lights, they would blink and then stay on. Now, since Friday, my dash lights do not work, nor do my tail lights (brake, reverse, and turn signals work). The warning indicator is not staying on...just flashed that one time when I couldn't get it to start, and then if I turn the ignition into the on position (car not running), it is there for a few seconds. I know I need to take this in...but I am wondering about cost? Any ideas?
Old 05-11-2009, 08:15 PM
bigtsr's Avatar
bigtsr
bigtsr is offline
Sorry to hear of your problems,my SXT is 3 yrs old also.
I might suggest checking your battery terminals for corrosion
and as has been posted many times removing the negative
terminal for abt 10 minutes sometimes will reset the computer.
If possible measure your battery voltage it should be 13volts dc
or more under no load,orig batteries are notorious for causing
wierd problems.
Old 05-12-2009, 05:00 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
I agree, sounds like a low voltage issue. Should be around 14 to 14.5v running and no lower than 12v with everything off.
Quick Reply: Electronic Throttle Control System
