tires
Trending Topics
Then it is a complete different set of wheel, you just have to test fit it like lxman said. Some wheel have different bolt pattern, and some have different off set that might not clear the brake or the suspension.
Tires upsizing
First: I've had my 2007 Caliber since (almost) new. No serious problems-- only major repairs were replacing some front end parts. 130,000 miles now. Love this vehicle.
My only complaint is the handling, which has always been a little sloppy. The front end rebuild helped, but, since it's time to replace the tires, I'd like to upsize the tire size.
At a great website, https://tiresize.com/comparison/, you can see and compare specifications for different sizes. The stock tires are 215 60 17. I'm considering 235 45 17, and 225 55 17. These are small changes, but both are slightly wider tires (the latter is also slightly smaller diameter). I expect this change will mean better cornering, with a slight increase in ride roughness and perhaps a minor inaccuracy in speedometer reading.
Any thoughts on whether either or both of these sizes will work? I can't "try out different sizes" on it, since I'm ordering the tires shipped in, and I have to pay $15 per wheel for mounting and balancing.
