How to fix p0010 code
Hey everyone, I've searched online for awhile now and I can't find a definitive answer to my problem. A few weeks ago, my 2011 Dodge Caliber Mainstreet's alternator crapped out on me. I had it replaced and changed, including a new battery, and then my check engine light came on. It's been giving out the code P0010. The shop I got my alternator replaced at told me it was my camshaft position sensor. So I changed it, but the code keeps lighting up. I've driven over 300 miles on the new sensor, hoping that it just needed to reset itself, but no luck. I've disconnected the battery hoping that would reset it, no luck there either. I'm stumped on what to do next, if anyone has any ideas I would love to here them. Thanks for your time.
the dtc sets for an open circuit.
gm posted ohm spec for their actuators but I don't see them for dodge.
I would test the grd wire; remove the connector to the bank1 camshaft 1 actuator. clamp a test light to b+ and back probe the black/white wire. it should light the test light.
without a scan tool to actuate the solenoid, you will have to disconnect the pcm harness and ohm check it from the pcm connector 2 pin 23 to the brown/white wire.
if that's ok replace the actuator. ifs that does not fix it; bad pcm. let the dealership have at it if the actuator and wiring check out.
I worked for gm and the actuators would go bad on the ecotec engine all the time.
